Mystery internal fuel tank pressure - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 11 Old 08-05-2019, 03:48 PM Thread Starter
Question Mystery internal fuel tank pressure
My DL 650 presented me a mystery!
Every time I open the fuel cap, there is a pressure relief, even after a night in the garage.
The motorcycle operates normally, if it weren't for the pressure relief I wouldn't have noticed the problem. It doesn't matter, apparently, if fuel level is high or low. Temperatures are around 27 C these days. I first noted the problem about 1 month ago.
I can´t find the cause of this, and neither can Suzuki´s mechanics in my city. All hoses are unblocked. They started trial and error problem solving and that bother's me a lot!
Any insights or suggestions, people?
dkostrisch is offline
post #2 of 11 Old 08-05-2019, 04:45 PM
Big Boy's Avatar
The pressure relief valve inside the gas cap could be blocked.
W. C. Fields
Big Boy is online now
post #3 of 11 Old 08-06-2019, 03:08 AM
Gert's Avatar
Have you previously lifted the fuel tank? It could be that one of the fuel tank hoses is pinched / kinked, when the tank is lowered in place.
Gert is offline
post #4 of 11 Old 08-06-2019, 03:58 AM
Rolex's Avatar
Are you sure it's pressure and not a vacuum ??
If you don't start the motor between tests do you get the same result ??
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #5 of 11 Old 08-09-2019, 01:43 PM Thread Starter
Thank you, Big Boy!
I dismounted completely the fuel cap, and confess that the relief system is complicated, I sdidn't fully understand it. Too many valves and calibrated passagers... but I found nothing obstructed or stuck, so I mounted again and installed in the tank.
Still not OK...
post #6 of 11 Old 08-09-2019, 01:45 PM Thread Starter
Thank you, Gert!
I checked the canister, the hoses and the routing, everything OK with, nothing pinched or obstructed.
post #7 of 11 Old 08-09-2019, 01:47 PM Thread Starter
Thank you, Rolex,
Yes, I am positive it is not vacuum. I check after some period parked, and if it is sunny that is quite a strong gas vapor expelling.
post #8 of 11 Old 08-10-2019, 02:23 AM
Gert's Avatar
Gert is offline
post #9 of 11 Old 08-13-2019, 11:16 AM Thread Starter
Thank you, Gert, the second link you suggested has a relevanmt discussion indeed. I asked for help there...
Gert likes this.
dkostrisch
Suzuki V-Strom DL 650 XT 2017
Previous bikes:
Honda Transalp XL 700 VA 2011
Honda Falcon NX4 2008
Honda CB 400 1982
Honda CG 125 1979
Honda CB 50 1974
post #10 of 11 Old 08-17-2019, 08:19 PM Thread Starter
Hello, my friends!
I finally cracked the vapor accumulation problem in my wee.
Though I am not much of a mechanic, I gave up on Suzuki and decided to take the tank off and check all the circuit.
To my perplexity, i discovered the problem in less than 10 minutes. The hoses for vapor collection to the canister and for water drainage from around the cap were inverted, each connected to the wrong tube out of the tank. There was even water accumulated in the vapor hose, before the gasoline check valve. I purchased this byke a few weeks ago, and the previous owner must have the tank connections inverted.
After re-inverting the hoses, the problem was gone. So much for Suzuki service... it is my first Suzuki after 45 years of Hondas, and I never encountered such an incompetent/negligent service.
Thank you all for your advice, for the diagrams and for the discussions that made it possible for me to solve the problem. This is a great forum!
Gert likes this.
dkostrisch
Previous bikes:
Honda CB 400 1982
Honda CG 125 1979
Honda CB 50 1974
