Mystery electrical connection - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Brockie
post #1 of 6 Old 08-02-2019, 10:21 PM Thread Starter
I am reassembling my 02 dl 1000 and I have a wire connection without a mate. This is located behind the radiator. Looks like an orange with a green stripe and black with a white stripe.
Any ideas?
shadowtrekkor is offline
post #2 of 6 Old 08-02-2019, 10:46 PM
I don't know, does your machine have heated grips? If so where are they getting their power/ground from? Somewhere on this site someone must of posted a wiring diagram for your model year. The diagram should be able to confirm if that's the plug for the heated grips. I have a different year 650 so I'm not much help but someone in the know hopefully will chime in shortly...
gdrew is offline
post #3 of 6 Old 08-02-2019, 10:59 PM Thread Starter
No heated grips. Eastern Beaver headlight harness and lowbeam cut out switch. But these utilize the stock harness connections. I took photos of the wiring during disassembly. Somehow I missed this one.
post #4 of 6 Old 08-03-2019, 12:19 AM
Brockie's Avatar
The O/G and B/W wires are there for your "heated grips".
If you intend to wire up any other accessories, these are the OEM keyed wiring source - no risk of leaving something on and draining your battery.
Gert likes this.
Brockie is offline
post #5 of 6 Old 08-04-2019, 07:32 AM Thread Starter
Thanks Brockie for the assistance.
I wasn't closing this up until I knew what that was for.
Shadowtrekkor
post #6 of 6 Old 08-04-2019, 08:12 AM
teevee's Avatar
and FYI, you can buy a connector for that and have an oem, fused, switched power source up front.
'08 DR650, '07 DL1000
teevee is offline
