Will a DL640 2008 fuel tank fit on a 2006 bike? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By gdrew
post #1 of 6 Old 07-28-2019, 06:59 PM Thread Starter
Hi guys,
I have a 2006 DL650 and the tank is rusted out. I have an opportunity to grab a 2008 fuel tank as replacement, they look the same however the part numbers are different. I am having trouble finding out what year ranges are compatible. Anyone able to assist?
Cheers,
Adrian.
Adrian_74 is offline
post #2 of 6 Old 07-28-2019, 09:36 PM
Rolex's Avatar
I think you will find the part number will change because the colours will change from year to year.
You could search that out by looking at the numbers starting before and after your bike.
You could search out things that don't have paint on them to compare numbers, things like the pump, the flange the pump mounts to, the fuel cap and any plastics that bolt to the tank.
I'm 99% sure it will fit, sure enough that if I were in your position I would by the tank.
Some places have different pollution controls so there are some small changes to the fuel system, shopping locally would help with that but I'm sure it is nothing that can't be overcome if needed.
This is where GW is greatly missed.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 6 Old 07-28-2019, 10:24 PM Thread Starter
Thanks for the response! Have been having a further look and the part numbers are slightly different. The last number is the color code but the middle numbers change between the models. Between the years it is slightly different.(shown with xx)
The rest matches.
E.g.. 44100-06Gxx-ybb<- Blue
post #4 of 6 Old 07-29-2019, 01:04 AM
My son and I have 2006 & 2008 DL650's. I've had the tank off of both bikes and honestly if there is a difference it wasn't apparent to me. The 2006 has a slightly different fuel pump than the 2008 but that's not the tank, just the pump. The mounts for the tank to frame and plastics to tank were identical if memory serves me, but I didn't have both bikes apart at the same time. My "opinion" is that the 2008 tank will work on the 06 and if I were in the same situation as you I would proceed with purchasing the 2008 tank...subject to someone else chiming in here advising not to proceed.
Sorry, that's the best I can do.
Gert likes this.
gdrew is offline
post #5 of 6 Old 07-29-2019, 02:48 AM
Gert's Avatar
Agreed, that the DL650 fuel pumps are different for the K4-K6 and K7-L1. The physical fuel tanks should be the same, but later models may have different tupperware to the tank mount positions.
Gert is offline
post #6 of 6 Old 07-29-2019, 03:50 AM Thread Starter
Thanks again all.
I have done a bit more comparison of part numbers across the 2 years. Seems the fuel cap is the same and the side covers also so they should line up. The lower mount seems to have a different code however when I do comparisons around different sites it seems interchangeable as they seem to state it is usable for various models. ei same year models quote either part depending on site.
I guess I will give it a few days and unless somebody out there comes back with a definitive answer I will take a punt, cross my fingers and purchase. :-)
