Grommets for Bestum Topbox? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By NVDucati
  • 2 Post By LL Fauntleroy
post #1 of 9 Old 07-26-2019, 10:34 AM Thread Starter
LL Fauntleroy's Avatar
Need the rubber grommets that prevent the box from rattling from vibration, the old ones have disintegrated. Any idea where to get these or what else to use for this purpose? See photo
LL Fauntleroy is offline
post #2 of 9 Old 07-26-2019, 11:01 AM
I think an automotive parts store may be your best bet but you may have to improvise a bit. It's possible to find the exact grommet you're looking for, or one that fits the mount but might need to be cut shorter.
gdrew is offline
post #3 of 9 Old 07-26-2019, 11:22 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
richlandrick is offline
post #4 of 9 Old 07-26-2019, 02:05 PM
Build it up with JP Weld and reshape it?, Fiberglass work?
I run a strap around that sort of top box to avoid excessive vibration. My JC Whitney box is quite old and no wear like that.
post #5 of 9 Old 07-26-2019, 02:35 PM
NVDucati's Avatar
Originally Posted by richlandrick View Post
That is a good one.
Another (if you have a store near you) is Fastenal https://www.fastenal.com/product/cut...sExpanded=true
Neoprene washers are very durable and a stack of them will give you the cushion you need.
Even black automotive fuel line hose can work.
Hint: A rubber washer(s) with 4 or 6 razor slits radiating out from the center hole will allow you to push them over the mushroom head in your photo.
notacop likes this.
Member: AMA
NVDucati is offline
post #6 of 9 Old 07-26-2019, 03:51 PM
Stalky Tracker's Avatar
Some Ace Hardware's have them. Saves time and an order to McMaster Carr.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #7 of 9 Old 07-26-2019, 04:17 PM
RCinNC's Avatar
Grainger is another industrial supplier that I frequently use, along with McMaster Carr. They have a ton of different grommets.
www.grainger.com
RCinNC is online now
post #8 of 9 Old 07-27-2019, 10:14 AM
Rick505's Avatar
I put a short section of vinyl/Rubber tubing on the existing rubber bumper thing on the mount to take up any "slack". I had to play a bit finding the ciorrect length but something like an inch if I recall (and I probably don't) correctly.
Rick505 is offline
post #9 of 9 Old 07-29-2019, 04:02 PM Thread Starter
Ace hardware, little rubber grommets, .48 cents ea did the trick. They were flexible enough to force them over the post, leaving enough room to slide the box over
Stalky Tracker and Gert like this.
