How frozen is a frozen link? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 21 Old 07-23-2019, 09:11 AM Thread Starter
Ahoy there,
I am trying to understand if my chain has frozen links, and... well... I could use some help.
The chain has around 6000km on it, I was expecting it to last at least 3 times that. It was in good conditions when I stored the bike before the winter. The bike was inside a shed, covered by the rain, but still an outside shed and this winter was quite cold and wet. When I picked it up I found small rust spots on some links which I cleaned with a metal brush and WD40. Now some of the bushings (the metal cylinder around the rollers) do not freely roll (the other would keep on rolling once started), the chain links can be moved although some offer some resistance... now I cannot remember if this was the same as the new chain...
Is there a way to tell if the links are frozen and beyond saving? I'd rather avoid spending extra money for a perfectly fine chain, on the other hand if the chain has started a downhill path with no return, maybe I should just change it now...
Thanks,
Teskio
2008 DL650A
Teskio is offline
post #2 of 21 Old 07-23-2019, 09:21 AM
Rick505's Avatar
I'm certain others will chime in but I'd lube it and run it for at least a couple of days. Then recheck it so see if it hasn't freed up. My "test" is will the chain sag evenly/properly between sprockets when not in tension. Then again, I'm cheap!
Rick505 is offline
post #3 of 21 Old 07-23-2019, 09:26 AM
WildDoktor's Avatar
Replace it...or replace your motor. Pretty simple math!
Sent from my SM-N920V using Tapatalk
MAZ4ME likes this.
WildDoktor is online now
post #4 of 21 Old 07-23-2019, 09:33 AM
chicago's Avatar
rust 'spots' aren't a problem but frozen links means o rings are compromised. I would replace chain. a wire brush can damage o rings.
Big B and MAZ4ME like this.
14 tooth for me
chicago is offline
post #5 of 21 Old 07-23-2019, 11:42 AM
BC Rider's Avatar
With only 6,000 on the chain you should be able to resurrect it. Use an old tooth brush and oil to work the oil into the rollers and coat the O rings. WD 40 is a penetrant and doesn't leave much lubricant after so i would avoid it at this point. The rollers will usually free up with oiling and use as they are not sealed and fresh oil can work in and wash out the rust. Stiff or frozen links( the ones that look zig zaged after coming off the front sprocket ) can be worked by carefully grasping the center of the link from the side with needle nose pliers and twisting it back and forth. You are trying to work some oil into the dried out O ring. If the sealed part of the chain, between the pin and bushing, has lost its grease and is rusting the chain is done. Though a buddy that had one badly frozen link pushed the offending pins out and riveted a new greased up master link in to the spot. He got about another 10k out of the chain.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #6 of 21 Old 07-23-2019, 11:54 AM
Big Boy's Avatar
How often do you lube your chain??? Have you ever used solvents to clean your chain???
My last chain had over 33,000 miles (61,000 km) with no tight links and I NEVER used any solvents to 'clean' it.
W. C. Fields
Big Boy is offline
post #7 of 21 Old 07-23-2019, 12:02 PM
blaustrom's Avatar
All good comments.
What make is the chain? Was it a "cheap ebay find" or a reputable maker product?
When you pull at the chain on the rear sprocket at the 3 o'clock position, can you pull it off the sprocket and see light between the chain and the sprocket?
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is online now
post #8 of 21 Old 07-23-2019, 01:10 PM
I would start with ATF. It will help the O-rings & penetrate better than the thicker stuff. If it comes back to life, I'd be using a dedicated chain lube on it. Also, it will most likely get quite lose as it frees up.
WD-40 washes lubricant away. WD means Water Dispersant. It has its uses, but I don't use it on my chain as a lube.
2007 DL 650 with assorted upgrades
Solo is offline
post #9 of 21 Old 07-23-2019, 02:18 PM
I would start with ATF also and use it always. It softens dried out o rings and keeps them from drying out. of course the chain could be too far gone but try atf for some distance and see if it works or if the chain is too far gone.
RLBranson is offline
post #10 of 21 Old 07-24-2019, 03:13 AM Thread Starter
great, so the chain could have been ok right until the moment I used the wire brush...
2008 DL650A
Teskio is offline
