Proceedures For flushing brake fluid front dual caliper system DL 650 17 model - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 07-16-2019, 10:20 PM Thread Starter
RestoRider2017's Avatar
Location: Apopka Florida NW of Orlando near a twist in the road and a hill on the horizon...
What are the details on how to flush and refill the brake fluid when 2 calipers exist
in the system. Special tools involved ? Specifically the 2017 DL 650.
I have a pressure bleeder but not sure how to hook it up on a 2 caliper set up.
Any help would be great. jake
2017 DL 650 , Shad 23 bags, Givi crash bars, 32 watt LED aux lights , Goldwing pegs, Metalic silver front fender, Lazer cut aluminum Chain guard, Madstad 20" windshield
light smoke tint , Blu/blk Driven Racing Billet bar ends, Dbl Take adventure mirrors , BeadRider Ceramic bead seat cover on order.
Stock exhaust for now. Yoshimura 3/4 system simmering on low in the oven.
Avatar image is a custom made Harley Sportster all hand built from junk parts from a retired engineers desk. Took 80 hours to make.
RestoRider2017 is offline
post #2 of 5 Old 07-17-2019, 02:57 AM
Gert's Avatar
Have you had a look at any of the videos: How To Replace Your Motorcycle Front Brake Fluid | DL650 Vstrom L0 | Dr Vstrom Brake Series or V-Strom brake fluid change. Easy! or How To Bleed Your Motorcycle Brakes | Dr Vstrom Brake Series?
Gert is offline
post #3 of 5 Old 07-17-2019, 09:28 PM Thread Starter
I have not. But thanks for the tip Gert. I will check it out .
post #4 of 5 Old 07-17-2019, 10:13 PM
You said pressure bleeder - as in this forces new fluid back up the system from the caliper to the master cylinder? You would suction out the old brake fluid from the master cylinder or at least some of it (with a pressure system). Attach the bleeder to the brake caliper farthest from the master cylinder so new fluid forced into the system thru the bleed nipple will flow up the hose to the other caliper then up to the master cylinder.
Ratchet is offline
post #5 of 5 Old 07-18-2019, 06:19 AM
PerazziMx14's Avatar
Look up reverse bleeding on youtube there are lots of videos. You'll need a big syringe (available at any farm and fleet store or online) and a section of 5/16 ID poly hose (available at any home center)
When bleeding brakes always start with the caliper farthest away from the master cylinder. On motorcycles this is typically the front left then move to the front right.
Inexpensive Prestone brake fluid ($3.50 for a 12 ounce bottle) from Walmart in the right DOT is all you need. Just because its inexpensive doesn't mean its not good.
PerazziMx14 is offline
