givi rack Givi PL3112 question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-08-2019, 05:01 AM Thread Starter
Hi,
just got these racks and wonder what for is that exhaust part there, like a extension for the pipe,
is it necessary really? no problem with vibration later on etc?
offnote is online now
post #2 of 6 Old 07-08-2019, 07:34 AM
Gert's Avatar
Are you referring to the item #15 on drawing D of installation instructions, http://files.twistedthrottle.com.s3....vi/PL3112.pdf? To me, it appears to be an exhaust heat deflector. Whether you can leave it off, would be up to you. Imagine your bike idling for extended periods loaded with your luggage. My guess that there would be a certain amount of heat emitted from the exhaust. How much of that heat will reach your luggage, is something you can perhaps test for yourself. Maybe I'm wrong... Will it rattle? I guess that will depend on how it is installed. Certainly not enough info in the instructions on the subject.
Gert is offline
post #3 of 6 Old 07-08-2019, 07:55 AM Thread Starter
yes, probably you're right, it will be heat deflector. not sure if all cases need that, I have trekker 2x33 boxes.
Something to test it, other possibility to glue some metal shield under the case.
thanks.
post #4 of 6 Old 07-08-2019, 11:45 PM
K9 Wee's Avatar
Hi Offnote -
Looks like that part is a tailpipe extension to move exhaust gas (as well as heat and oil/carbon/soot) away from end of muffler (and your sidecase). It appears to be supported by the Givi rack. Would want to see how that fit against muffler and maybe use a silicone washer (you could make one out of kitchen utensil) to eliminate a vibration point.
______________________
2009 Orange DL650
SW Motech Rally Crashbars, Skidplate & Centerstand
Givi e22L Sidecases
Shad 33L Topcase
Wolfman 40L Waterproof Duffel
Givi Tanklock 25L Tankbag
Techiwik Long Underwear
1978 Honda CB550K-Sold
K9 Wee is offline
post #5 of 6 Old 07-09-2019, 01:34 PM Thread Starter
OK, I tested it, rode 30 miles and my side case is not even warm so I guess this part is not needed for givi trekkers,
post #6 of 6 Old 07-10-2019, 11:03 AM
Gert's Avatar
I don't think that riding will give the same heat issue on the luggage, as exhaust heat when stationary while idling for extended periods. Could be that Givi is making allowance for any possible chance of damage to soft luggage and / or bigger luggage. I suggest that you should test by letting your bike idle for a few minutes, once at full operating temp, for any heat transfer from the exhaust to the cases. If no heat transfer, then the exhaust extension may not be required for your current cases. However, if you should ever change your luggage to bigger cases or soft luggage, I think it prudent to re-test for heat transfer.
Gert is offline
