'09 1000 Intermittent power loss/ 30-32 mpg??? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Brockie
post #1 of 9 Old 07-06-2019, 08:00 PM Thread Starter
rjpstrom's Avatar
Angry '09 1000 Intermittent power loss/ 30-32 mpg???
Hey all!!! My '09 DL 1000 is losing power during my rides where I lose the exhaust note and about 10% of the power for about 5-7 minutes then everything is fine again for 20 minutes or so and this happens over and over during my rides. I also get the occasional backfire through carbs(1-3 times per ride, sometimes at start up), and I am constantly getting 30-32 mpg. TB synced, TPS adjusted, new air cleaner, checked air cleaner boots/on tight, Disconnected PCV just in case that was doing it. I am hoping somebody somewhere might know something so I won't have to take to the Dealer. I was thinking bad ECU?? Thanks in advance!!!!!!!! Bob.... '09 DL 1000.
rjpstrom is offline
post #2 of 9 Old 07-06-2019, 08:01 PM Thread Starter
rjpstrom's Avatar
'09 Intermittent power loss/ 30-32mpg????
rjpstrom is offline
post #3 of 9 Old 07-06-2019, 09:09 PM
blaustrom's Avatar
Check battery connections and main ground at both ends.
Add info where you are and model/ mileage to your signature to get better answers.
Also list all the major maintenance items that have been done recently or are overdue.
Seems to be an intermittent problem, possibly electric. When it does it check if both exhaust are hot or one maybe not as much, missing spark or problems with one injector.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #4 of 9 Old 07-07-2019, 12:40 AM
WildDoktor's Avatar
If you have aftermarket pipes and a power commander, I'd check that the power commander doesn't have a loose power connection...
2004 V-Strom 1000 (currently broken - parts received - repairs in progress - snag hit - repairs on pause)
Two Brothers with P1 tips, PCIII USB, SuperBrace Fork Brace, K&N filters, ROX bar risers, Kappa top and side cases, MadStad, Givi tall windshield, Givi engine guards, Sargent Seat, 12 volt air compressor, 530 Conversion, 17/44, SpeedoDRD
WildDoktor is offline
post #5 of 9 Old 07-07-2019, 02:50 AM
Gert's Avatar
When last were the valve clearances checked? It could also be a plug lead not making proper contact. Have you read https://www.vstrom.info/Smf/index.ph...,13313.0.html?
Gert is offline
post #6 of 9 Old 07-07-2019, 03:21 AM
Gert's Avatar
Duplicate post https://www.stromtrooper.com/v-strom...ml#post5411023
Gert is offline
post #7 of 9 Old 07-07-2019, 05:19 AM
Brockie's Avatar
There is also the possibility of a blocked fuel filter. Look through this thread for a fuel flow test. https://www.stromtrooper.com/dl1000-...tps-issue.html
There is a youtube video on how to replace a DL650 filter here:
Gert likes this.
Brockie is offline
post #8 of 9 Old 07-07-2019, 06:59 AM
Gert's Avatar
For those who may want some insight on the Symptoms of Lean or Rich fuel settings on a motorcycle, https://mechanics.stackexchange.com/...n-a-motorcycle. I know that the write-up refers to carb settings, however the fueling symptoms are very much similar for both the carburetor or the fuel injection. The spark plug chart explanation is also the same for both fuel systems. Start from the heading "Symptoms of Lean and Rich".
Gert is offline
post #9 of 9 Old 07-07-2019, 10:38 AM
blaustrom's Avatar
So RJP, what have you done? What have you found?
Blau2 2014 DL1000A
