Clutch cover won’t budge - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By Gert
  • 1 Post By BC Rider
post #1 of 5 Old 07-02-2019, 12:55 AM Thread Starter
Everything disconnected and all 13 bolts are out. Clutch cover won’t budge for removal. Any tricks to this?
Thanks.
Birchgroover is offline
post #2 of 5 Old 07-02-2019, 02:23 AM
Gert's Avatar
Try tapping around the casing with a rubber mallet, to shock the casing loose and if necessary, apply a bit of heat to soften the gasket seal. Either way you will need to change the gasket.
Birchgroover likes this.
Gert is offline
post #3 of 5 Old 07-02-2019, 02:26 AM
BC Rider's Avatar
There should be two alignment pins installed. Which means the cover has to come straight off not sideways. Tap around the cover with a soft blow hammer carefully. The gasket alone will often lock the cover in place. I have had to tap a box cutter blade into a few to get it started. Be careful not to damage the sealing surface. An eight of an inch max should get it started. Then tap more around the cover. Pick a not so visible spot at a bolt with a boss proud of the case to reduce possible damage to the surface that seals against the gasket.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #4 of 5 Old 07-02-2019, 03:03 PM
Rolex's Avatar
Remove the dip stick, put in some padding so you can't damage the threads.
Use a long leaver or a ratchet strap to apply pressure then tap with a rubber mallet.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #5 of 5 Old 07-02-2019, 09:33 PM Thread Starter
Got it. Thanks guys.
