Please help, stalling and vibration issues - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 12Likes
post #1 of 18 Old 06-22-2019, 06:35 PM Thread Starter
2003 DL-1000
27k miles
Remus exhaust, stock air filter.
My bike was having issues where it would stall if I pulled the clutch in to coast to a stop. Plus I had a coolant leak and a vibration issue.
So I replaced all of the coolant hoses, the TP and STP sensors, synced the throttle bodies, and installed a Power Commander with a program for my exhaust and the V-Strom still runs the same as it did before. And what I mean by runs the same, I mean runs like shit. It still stalls when I pull the clutch in and coast to a stop.
TP and STP sensors and TB sync were adjusted per the shop manuals directions. I think, since Iím new to doing this.
Also, Iím still getting a vibration that I can feel through the pegs, seat and handlebars that becomes very noticeable at 5k rpm and up. It becomes even more noticeable when I hammer the gas.
So, please help me out here fellas, what do I need to do here?
husky390 is online now
post #2 of 18 Old 06-22-2019, 06:58 PM
Dark Angel's Avatar
Couple of things there.
When you say you replaced the secondary throttle position sensor, do you mean the servo? The sensor is on the primary plates.
When were the valve clearances last checked and the spark plugs changed?
Those models are known for what's called "clutch chudder" which would explain the vibration, though these all tingle a little bit.
The other thing you need, and I mean NEED, is to go get some rider training because coasting into the lights like that is very bad riding technique.
Motorpsychology likes this.
Dark Angel is offline
post #3 of 18 Old 06-22-2019, 07:00 PM
larolco's Avatar
My guess is that the TBS was not done correctly. There is a stop screw that can keep the adjuster screw from doing its job. The manual says to keep a certain clearance. If you turn the adjuster screw too far and use up that clearance it is impossible to set the TBS properly. Review the manual procedure carefully.
It could also be that the TPS was set without the bike at the proper temperature. That throws the setting off.
Check also your idle speed (mine likes to be around 1200).
You likely also have a shit clutch basket. Realshelby here can help you out with that.
Above all, though, please provide us with the bike's history. How long have you had it? Did it just start doing this or has it done it the entire time you've owned it?
DRZ400SK17
larolco is offline
post #4 of 18 Old 06-22-2019, 08:03 PM
He may well benefit from a clutch basket. But it isn't doing the things he is complaining about so we will leave that to later.
Several things jump out. But a big one is the stalling and vibration under load. I will bet power is down. You may have a cylinder not firing correctly. A likely cause is a throttle body boot out of position allowing air to bypass the throttle body blade. Would explain your symptoms.
I would carefully inspect those first.....
Big B and Twangthing like this.
realshelby is online now
post #5 of 18 Old 06-22-2019, 08:48 PM
A question Husky: Does it stall coming to a stop with the transmission in neutral and NOT pulling the clutch lever in?
MAZ4ME is online now
post #6 of 18 Old 06-22-2019, 09:01 PM Thread Starter
History of the bike. I bought it two years ago with 23k miles. Itís always been ďvibeyĒ since my first test ride but the vibration has gotten progressively worse.
Maintenance performed since buying it.
New spark plugs
New air filter
Both throttle body sensors have been replaced
Valves have not been checked
New chain and sprockets
I just cleaned the chain and everything inside the counter sprocket cover which was pretty goopy with chain lube
New rear wheel bearings
Tires are good
New Power Commander
I have rider training, and donít coast to a stop. My bad for not being more clear on when it does it.
It will stall as I pull the clutch in in the last couple of feet before I stop. Sometimes it will catch itself and idle normal other times it stalls. It started doing this last summer and became a more constant issue.
post #7 of 18 Old 06-22-2019, 09:02 PM Thread Starter
I donít believe so but will try it tomorrow hopefully.
post #8 of 18 Old 06-22-2019, 09:10 PM
Just trying to ascertain that if your stalling system is related to your clutch switch.
husky390 likes this.
post #9 of 18 Old 06-22-2019, 09:13 PM Thread Starter
Iíll give it a shot.
post #10 of 18 Old 06-22-2019, 10:03 PM
teevee's Avatar
idle speed? and valves are about due for a check.
'08 DR650, '07 DL1000
teevee is offline
