fuel tank hose connector - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By brutalguyracing
  • 1 Post By Solo
post #1 of 7 Old 06-17-2019, 05:36 AM Thread Starter
I managed to damage the green slide lock that connects the fuel hose to the bottom of the tank.
It seems to function just fine at this point, but I would like to restore it without replacing the entire assembly.
One leg of the [ C ] shaped hasp has its tip missing,I cable tied it for a backup.
Any input? Thanks
2006 DL 650
2018 DL1000A
jmvs is offline
post #2 of 7 Old 06-17-2019, 07:57 AM
Try this
Sent from my E6810 using Tapatalk
Hatchi likes this.
brutalguyracing is offline
post #3 of 7 Old 06-17-2019, 11:11 AM
blaustrom's Avatar
Next time you take the tank of, remove the green part, go to the auto parts store and see if they don't have a connector with the same design and swap the green clamp out.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #4 of 7 Old 06-17-2019, 05:48 PM Thread Starter
The 2018 1000 has a different style connector than the one in post 2.
You pull a clip away from the hose and it slides off .
to replace , push it fully past the barb and return the clip into its slot.
Use your fingers, not long needle nose. Doh!
I have an upcoming trip, so I was hoping there was some research out there on this.I know if Mr Greywolf was still with us he would have a labeled picture, a schematic and a part #, I guess we will have to carry on , its no big deal until it lets loose out on the road, but I think it should hold with the tiewrap.
2006 DL 650
2018 DL1000A
jmvs is offline
post #5 of 7 Old 06-18-2019, 07:30 AM
Rolex's Avatar
When I got my 2014 V2 that clip was damaged so I swapped it for another one on the bike that was only going to be used if I was to remove the throttle bodies.
I'm not sure if that will work on your bike.
On the V2 you don't remove the clip you just pop it up as you push back on the hose, there is a slot in the clip to fit the flat end of a screwdriver then twist.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #6 of 7 Old 06-18-2019, 08:37 AM
When I had a problem with my fuel connecotr, I solved it with the fuel hose and two metal hose clamp:
bronhi is offline
post #7 of 7 Old 06-18-2019, 01:12 PM
I wouldn't trust that type of clamp. Go to NAPA or who ever & get the high pressure type of clamp.
I've had my tank off several times & the OE connector is a non-issue.
Rolex likes this.
2007 DL 650 with assorted upgrades
Solo is offline
