Starting Up Stored Bikle - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Fox
post #1 of 4 Old 06-12-2019, 07:27 PM Thread Starter
KimR's Avatar
My 2007 WeeStrom has been sitting for a year or so. I popped in a new battery and tried to start her up, but no joy. The fuel light came on. I opened her up and discovered that the tank was bone dry. I add a gallon of 91 octane and a little SeaFoam injector cleaner. Still no joy. Next steps?
KimR is offline
post #2 of 4 Old 06-12-2019, 07:35 PM
Fox
Fox's Avatar
Do you hear the fuel pump spin when you turn the ignition on? If so I would pop the fuel line off and put a funnel underneath, flip the ignition on and off, and see if the fuel is flowing. If it's not, my money would be on a clogged fuel filter.
Gert likes this.
Fox is offline
post #3 of 4 Old 06-13-2019, 02:52 AM
Gert's Avatar
Make sure that there is no CHEC displayed in place of the clock. A chec display points to side stand down in gear or cutout switch. Also don't forget to check the clutch switch is being activated via the clutch lever or not perhaps the connector come adrift.
Gert is offline
post #4 of 4 Old 06-13-2019, 05:49 AM
PerazziMx14's Avatar
Does no joy mean the motor turns over but does not start or does no joy mean you push the starter and nothing happens?
PerazziMx14 is offline
