2015 DL 650 fuel disconnector jammed - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 14 Old 05-31-2019, 01:18 PM Thread Starter
burrhead's Avatar
I have about 16K miles on this bike and I started taking it apart to do a valve check today. Long story short, the quick connector on the fuel line is jammed at the tank. I cant depress the blue tabs to release the fuel line for love or money. Been at it for a couple of hours now and have had to walk away for a bit.
Tried squeezing the tabs with a small pair of channel locks (no go) and then tried using a small hose clamp to squeeze the tabs. Nope. I live 250 miles from town so a dealer is out of the question. I can't even find the part online so that I can trash the one I have and replace it.
Don't know where to go from here. Any help will be appreciated. TIA
Join the NRA
The older I get the better I was.
burrhead is offline
post #2 of 14 Old 05-31-2019, 02:01 PM Thread Starter
burrhead's Avatar
Nevermind. I just got pissed and went mid-evil on it and unplugged it without damage. What a cluster. Thanks for your attention anyway.
Join the NRA
burrhead is offline
post #3 of 14 Old 05-31-2019, 02:41 PM
Motor7's Avatar
About one out of 5 times I unplug those things they hang up...no idea why. So far no damage............
'15 DL650XT
Motor7 is offline
post #4 of 14 Old 05-31-2019, 02:51 PM
D.T.'s Avatar
Try pushing it in after you depress the tabs. Wiggle it off.
Thatwasclose likes this.
D.T. is offline
post #5 of 14 Old 05-31-2019, 03:13 PM Thread Starter
burrhead's Avatar
Well I pushed it in then got a small flat screwdriver on each blue tab and wedged them under the black coupling. It's like juggling cats. Anyway, a little prying on both sides with some judicious use of the King's English and it just came apart like fresh grease. I donno but it worked.
Join the NRA
burrhead is offline
post #6 of 14 Old 05-31-2019, 04:30 PM
locoblanco's Avatar
Sometimes you have to just walk away for a few minutes to calm down and regroup, then it goes smoothly.
locoblanco is offline
post #7 of 14 Old 05-31-2019, 07:14 PM
I used Dorman 800-081 fuel Line Quick Disconnect, 5/16 on my 2013 dl650
Hatchi is offline
post #8 of 14 Old 05-31-2019, 10:14 PM Thread Starter
burrhead's Avatar
How did you attach the aftermarket disconnect to the existing fuel line?
Join the NRA
burrhead is offline
post #9 of 14 Old 05-31-2019, 10:27 PM
blaustrom's Avatar
Look at the Dr V Strom Video just before 20 minutes into the video. It helps if you make sure there is no tension on the retaining clip, so push the fuel line connector a bit towards the pump and it should come right off, as he shows:
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #10 of 14 Old 06-01-2019, 01:39 AM Thread Starter
burrhead's Avatar
Cool. Thanks
Join the NRA
burrhead is offline
