Broken down in Houston - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 05-20-2019, 09:25 AM Thread Starter
The left front seal went out on my '11 Wee 400 miles into my trip to Colorado. I limped back to Houston and need a recommendation for a good mechanic that can help. I don't have the tools nor have I ever done a seal replacement and think someone who's done them before is the best way to go. Thanks in advance for any advice or help.
leftfield123 is offline
post #2 of 2 Old 05-20-2019, 09:36 AM
https://blacklabadventures.com/
The how is here but with no tools, that may be a bit of a bother.
I had a seal going out in St Paul Mn and rode the bike back to Calif by way of Jelleystone NP.
You could try pulling the cap and refilling, try using a flexible bit of plastic to swipe the seal area to clear a bit of offending dirt that may be causing the leak.
Your ride is degraded but not impossible.
Need help with a broken bolt on the casing. NineCows Maintenance, Tech and Products. 7 04-25-2019 03:01 AM
Broken chain, broken bike WildDoktor General V-Strom Discussion 34 03-06-2019 09:35 PM
Broken wires - Admore light kit in Givi E52 racefan Maintenance, Tech and Products. 6 04-13-2014 07:30 PM
Houston to Fairbanks & Return - Tires, Chain, Maintenance and Final Thoughts JerryM General V-Strom Discussion 7 07-25-2011 04:25 PM
Houston to Fairbanks and Return on the same set of tires! JerryM General V-Strom Discussion 33 07-24-2011 11:19 AM
