Oil Leak - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 05-19-2019, 03:32 PM Thread Starter
Kilt Guy's Avatar
Oil Leak
Cleaning the 12 Vee today and noticed on the left side around the clutch assembly area it is leaking oil.
Any one have an idea why and what I need to do to fix?
Kilt Guy is offline
post #2 of 5 Old 05-19-2019, 05:26 PM
nvr2old's Avatar
Are you sure it isn't brake(Hydraulic) fluid. The lower cylinder (Behind the sprocket cover) is a common problem.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #3 of 5 Old 05-19-2019, 05:59 PM Thread Starter
Kilt Guy's Avatar
No I am not. I just cleaned it up today and have not had time to tear it apart as I have another bike that has been getting all of my attention.
Kilt Guy is offline
post #4 of 5 Old 05-20-2019, 02:33 AM
Brockie's Avatar
The most likely suspects down there are either the clutch slave cylinder (as nvr2old says) or the countershaft oil seal.
The fixes are to rebuild or replace the slave cylinder, replace the push rod oil seal, or to remove the countershaft sprocket and replace that oil seal.
These threads may help:
https://www.stromtrooper.com/v-strom...placement.html
https://www.stromtrooper.com/dl1000a...d-leaking.html
https://www.stromtrooper.com/v-strom...ne-dl1000.html
Brockie is offline
post #5 of 5 Old 05-20-2019, 04:53 PM Thread Starter
Kilt Guy's Avatar
Thanks for the links. As soon as I get new fork seals in the Goldwing I will tear apart the Vee. Fun times
Kilt Guy is offline
How much is my bike worth? Oil leak. cappystromsocal DL1000 from 2002-2012 37 04-09-2019 11:24 AM
Oil leak high up on front cylinder BarnRat DL1000 from 2002-2012 9 02-28-2018 04:51 PM
Small oil leak at bottom of engine (DL1000) DesertBike V-Strom Service and Maintenance Questions and Discussions 36 01-18-2018 10:54 PM
How to find a brake fluid leak (rear)??? SWriverstone DL650 and DL650A - 2004 to 2011 5 08-25-2017 04:53 PM
Help identifying an oil leak? SWriverstone DL650 and DL650A - 2004 to 2011 5 07-15-2017 05:52 PM
