Sluggish starting and electrical issues - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 13 Old 05-19-2019, 08:41 AM Thread Starter
I recently replaced my battery and I'm not sure if I needed to or if I have something draining the new one. I put risers on my 2012 650 vstrom last year, but I never had problems until I tried adding a USB charger to the bike. Now I have menu selector changing every time I squeeze the clutch, and sluggish starting every now and then.
Any advise would be appreciated
WeeV8 is offline
post #2 of 13 Old 05-19-2019, 09:23 AM
Highwayman2016's Avatar
Is the USB charger on a switched circuit? I put one on my 2016 650 and have no problems but I put it on the heated grip circuit, which is powered only when the key is on. Most USB chargers draw power constantly. Have you checked to see how much power your charging system is putting out?
notacop likes this.
2014 650 Strom
Highwayman2016 is online now
post #3 of 13 Old 05-19-2019, 09:47 AM
Yah, if you just installed it and it doesn't work, you did something wrong. Try again.
I got funky volt meter readings until I reworked the source voltage. It was showing me what the line drop was for the accessories.
notacop is online now
post #4 of 13 Old 05-19-2019, 09:07 PM
Rolex's Avatar
Ensure your clutch leaver is not activating your flash to pass switch when it's pulled in
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #5 of 13 Old 05-19-2019, 10:18 PM
Coach23101's Avatar
Location: Seattle in the summer and East Cape, Baja in the winter. Perfect!
I don't understand this statement. USB ports do not draw power unless something is plugged into them. They are just like 12 V outlets.
Am I incorrect?
Coach23101 is offline
post #6 of 13 Old 05-20-2019, 12:11 AM
trapperdog's Avatar
Am I incorrect?
As long as there is power to a USB port, it’s busy converting 12V to 5V. It’s only drawing single to double digit MA so without additional parasitic draw or weak battery, etc a healthy battery should be good for a few weeks. A dirty battery surface can draw more than a usb and compound the problem further. Some eBay and Amazon units are illuminated causing higher MA drain.
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is online now
post #7 of 13 Old 05-20-2019, 03:01 AM
Rolex's Avatar
My reading & testing tells me that good quality USB's have a parcitick draw but the cheep elcrapo ones do not
Big B likes this.
2014 V2, Snoopy
Rolex is offline
post #8 of 13 Old 05-20-2019, 11:57 PM
Coach23101's Avatar
Originally Posted by trapperdog View Post
As long as there is power to a USB port, itís busy converting 12V to 5V. Itís only drawing single to double digit MA so without additional parasitic draw or weak battery, etc a healthy battery should be good for a few weeks. A dirty battery surface can draw more than a usb and compound the problem further. Some eBay and Amazon units are illuminated causing higher MA drain.
Hmm...
Without a load I wonder what USBs are busy. Converts to 5V, but wouldn't that be only when a load requiring current is present? No so consumption of energy when shut down.
Not chipped so no input polling consumption there.
Where is the draw via the USB in stasis?
post #9 of 13 Old 05-21-2019, 09:10 AM
Brockie's Avatar
Originally Posted by WeeV8 View Post
........I put risers on my 2012 650 vstrom last year, but I never had problems until I tried adding a USB charger to the bike. Now I have menu selector changing every time I squeeze the clutch, and sluggish starting every now and then.
I would never connect a power outlet to a non switched source. The potential to leave something draining the battery could be very inconvenient. The heated grips plug is the obvious source if you only intend to have one or two electrical accessories. Where did you source your power?
A parasitic drain could explain a less enthusiastic starter motor. Checks across the battery with a meter while the bike is sitting unused will identify this. In any case, taking the risk of forgetting to remove an accessory is just not worth it. Convert to switched power.
In your recent work you must have also rearranged the clutch lever/LH switch block relationship. The select button is on the front of the switch block - just where the clutch lever might touch it when pulled in. Move the lever, or the switch block.
Big B likes this.
Brockie is offline
post #10 of 13 Old 05-21-2019, 10:26 AM
trapperdog's Avatar
Hmm...
That’s beyond my pay grade However I do recall seeing youtube videos with inline meters showing the milliamp loss with no load when researching USB ports a few years back. I don’t recall why though.
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
Suzuki V-Strom 1000 Recalled For Three Separate Electrical Issues VS Jeff Home Page News 4 07-26-2016 07:31 PM
Electrical Issues with V2 kamikazejoshua DL1000A - 2014-2016 9 09-02-2015 07:46 AM
Issues starting this week, electrical.. fragile_this_side_up DL650A - 2012-2016 12 05-07-2014 07:39 PM
Strange electrical issues with new 2012 V-Strom 650 daltonrooney DL650A - 2012-2016 29 02-18-2014 08:46 PM
Loose electrical connection on clutch side is making starting the bike difficult arooni Maintenance, Tech and Products. 1 01-30-2013 01:16 PM
