Is my drain plug stripped? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 2 Post By MAZ4ME
  • 2 Post By Smidge
post #1 of 9 Old 05-13-2019, 05:09 PM Thread Starter
I recently bought a new to me 2008 v strom 1000. everything looked good, no leaks, ran healthy, sounds good. Im about to do an oil change and noticed this plastic thing around my drain plug. I thought it was just one of those automotive nylon gaskets. MY buddy seems to think that it is something to compensate for the bolt or the hole being stripped. anyone have any ideas?
I dont know what ill do if its stripped. id be pretty disappointed thats for sure.
Smidge is offline
post #2 of 9 Old 05-13-2019, 05:54 PM
Ive seen that before when the oil pan or case was stripped, and a self-tapping drain plug was used to.."repair" the threads. Remove the drain plug and see what you have.
Big B and Chipwidget like this.
MAZ4ME is offline
post #3 of 9 Old 05-13-2019, 07:28 PM
Brockie's Avatar
The oil drain plug should only be tightened to 16.5 ft-lb. That is not a lot.
Simplest solution: When you need to remove the oil drain plug to do an oil change see if you can identify the insert and purchase a spare from your auto parts store to use when the oil drain plug can no longer be tightened to 16.5 ft lbs.
Brockie is offline
post #4 of 9 Old 05-13-2019, 09:14 PM
Looks like a fix, if it works and doesn't leak oil, don't worry!
post #5 of 9 Old 05-14-2019, 12:51 AM
I'm not sure what I'm looking at, but it looks like a heli-coil that wasn't inserted all the way??
I duno, maybe I should'a shut up.
2007 DL 650 with assorted upgrades
Solo is offline
post #6 of 9 Old 05-14-2019, 01:10 AM
Sadly I think MAZ4ME is right. It could be a major hassle to get it back to original but OTOH you might get away with this fix for a long time.
Chipwidget is offline
post #7 of 9 Old 05-14-2019, 11:55 AM
Lui
On this topic of drain plug, I stripped mine several years ago, and was terrorized to see all that metal shavings coming out.
A helicoil thread insert was installed and is perfect, no problems, better than before.
Having said that, it is safer to be careful and not over torque AND get rid of that annoying OEM crush washer and install a new aluminum washer every time you change the oil.
Lui
08-DL1000
Lui is offline
post #8 of 9 Old 05-15-2019, 03:52 PM Thread Starter
So good news guys. Its not stripped! It ended up being one of those plastic automotive style gaskets, which looked to be too big and melted around the bolt from the high heat. was a PIA to get off my bolt. i have now replaced it with an aluminum washer. good to go.
Solo and Brockie like this.
Smidge is offline
post #9 of 9 Old 05-15-2019, 07:54 PM
Brockie's Avatar
Fantastic. Isn't it great when you find that your worst fears were unfounded? Not a very bright PO though.
Brockie is offline
Eco plug (oil drain plug) test roughroad DL650A - 2012-2016 22 03-04-2019 10:26 AM
Weird Oil Drain Plug Currenv V-Strom Service and Maintenance Questions and Discussions 18 03-03-2019 12:44 AM
Oil drain plug gasket removal FRIDAY BIKE Maintenance How-to 30 04-18-2017 04:32 PM
Help- What drain plug is this? mikejohnson DL650A - 2012-2016 8 08-18-2015 03:07 PM
Replace the oil drain plug washer... really? Prime General V-Strom Discussion 25 05-11-2013 11:40 AM
