DL650 torque value engine support bracket to frame - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Gert
post #1 of 3 Old 04-25-2019, 12:26 AM Thread Starter
What is the proper torque value of the 8mm bolt that connects the engine support bracket to the frame. This is for a 2017 model, but should be the same for any year? I've seen both 16.5 and 25.5lb.ft.
wolfcreek is offline
post #2 of 3 Old 04-25-2019, 06:14 AM
Gert's Avatar
https://www.stromtrooper.com/4139225-post3.html To quote the late greywolf " At least you used 16.5lb-ft instead of the 22.5lb-ft of torque wrongly stated in the service manual."
https://www.stromtrooper.com/v-strom...l2-1000-a.html Again from the late greywolf, "Torque specs are pretty much based on bolt size. If you aren't doing anything that you need to buy a service manual for, the generic chart is fine. Measure the shank diameter for bolt size.
4mm-1.5 lb-ft
5mm-3.0 lb-ft
6mm-7.0 lb-ft
8mm-16.5 lb-ft
10mm-36 lb-ft"
K9 Wee likes this.
Gert is offline
post #3 of 3 Old 04-25-2019, 09:28 AM Thread Starter
Well stated....Much thanks
SV650 Engine in a 2004 DL650 _Rob Maintenance, Tech and Products. 0 01-25-2015 08:29 AM
New, SV Racing Parts, Frame Sliders for the DL650 and DL1000 SV Racing Parts SV Racing Parts 68 04-05-2014 12:37 PM
DL1000 vs. DL650 engine smoothness question. Atagrob DL1000 from 2002-2012 59 05-16-2013 04:40 PM
Buying a Torque wrench. Max torque on Dl650 2012? weecan DL650A - 2012-2016 5 04-16-2013 03:20 PM
