tire balance - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 07-13-2009, 09:41 PM Thread Starter
tire balance
My 08 vstrom has a balance weight on the rear tire, but the front tire has nothing. Should I have the front tire balanced the bike is still under warranty. Has a bit vibration up front at low speed with little or light presure on the grips.
karl is offline
post #2 of 12 Old 07-13-2009, 10:06 PM
ksievers's Avatar
Send a message via AIM to ksievers
certainly worth asking the dealer at the least.. good luck
ST1300 '08
MCL Risers, grip puppies and throttle boss, that's it. "as is" is great.
V-Strom 650 K8 (sold - great bike tho)
Flat Black #117
Professor/Musician
Wee had: SuperBrace; Sonic Springs; MadStad (MP Cycle Grand Touring); Nelson-Rigg 850's; Bestem Top Case; Grip Puppies; Kuryakin Throttle Boss; Stebel, OEM HandGuards
ksievers is offline
post #3 of 12 Old 07-13-2009, 10:28 PM
Consider balancing at home for no charge. I balance at home and get it absolutely perfect, and would rather do it myself than pay for the bottom man on the totem pole at the dealer's shop to do it.
There are lots of posts on balancing on this site.
biggyfries is offline
post #4 of 12 Old 07-13-2009, 10:36 PM
Or get some dynabeads.
[URL="http://www.steelhorseraiders.com/jasons-bike/"]2009 DL650[/URL]
jasonslay is offline
post #5 of 12 Old 07-13-2009, 11:47 PM
Bisbonian's Avatar
My experience with an out-of-balance tire is that it shows up more at higher speeds.
The tires they put on these have a more aggressive tread and can give a bit of bumpiness at low speeds, especially with a light grip on the bars.
I've now had 4 different front tires on my Strom, the original Trailwing had and needed no weight; the Avon Distanzia and TKC80 I put on the next 2 times needed quite a bit of weight. The Anakee I have on there now has a small bit of weight.
The Distanzia & TKC80 were both smooth up to highway speeds until they got some miles on them and cupped. The Anakee gives me a bit of weave at low speeds with light pressure on the bars.
FWIW Dynabeads were not the answer for me in either of the tires I put them in, I won't use them again.
I guess what I'm saying is that you tire is most likely completely normal. You don't say how many miles you have on the bike or what condition the front tire is in so it's hard to make a determination of whether your front tire is in need of replacement.
If it makes you feel good then have the dealer look at it, personally if the symptoms are as you describe I'd just ride it.
Not all tires need balancing weights.
Go hang a salami I'm a lasagna hog
Bisbonian is offline
post #6 of 12 Old 07-14-2009, 12:00 AM
Raptor02's Avatar
Just had a set of Tourances mounted and while the rear required a weight, the front did not (stock Bridgestones required weight).
Asked the tech's about the lack of weights, and they rebalanced the wheel and tire (front) and again, no weights required, with no problems.
JC
Our Moto Photos - http://raptor02.smugmug.com/
Raptor02 is offline
post #7 of 12 Old 07-14-2009, 12:25 PM
VS650's Avatar
+1 on Dynabeads...
2008 Black V-Strom DL650 - Center stand - Grip Puppies - Kisan Tail & Path Blazer - DynaBeads - Bestem 2012 Top Case - OEM Hand Guards - Custom rear brake LED lights
VS650 is offline
post #8 of 12 Old 07-14-2009, 03:51 PM
Xavier6162's Avatar
I put Dyno Beads in my already perfectly balanced tires over a thousands miles ago. My tires at the time had 10,000 miles on them and looked as if I'd get another 8-10K.
The Dyno Beads threw the balance off. Cupped the front after just 100 miles. Anything over 75 MPH caused enough front end shake to make the mirrors’ useless.
I put the weights back on and can now at least do 85 MPH before the shakes starts. Now I just commute at 75 and deal with the minor cupped vibration.
Bought new Wings front and back but I'm reluctant to change out the tires because of the amount of thread left on the OEM. Maybe I’ll do it at around the ~16,000 mark.
One thing for sure, I won't be using Dyno Beads again.
I often lose control. I really I hate my life.
Xavier6162 is offline
post #9 of 12 Old 07-14-2009, 04:30 PM
jackpiner57's Avatar
Why would you do that?
And there was NO cupping on the front?
And you left them in? They cupped in 100 miles???
Is this with the DynaBeads out now?
OK, this part is a joke right?
"Build a man a fire and he'll be warm for the night. Set a man on fire and he'll be warm for the rest of his life." - Confuseus
jackpiner57 is offline
post #10 of 12 Old 07-14-2009, 05:43 PM
Xavier6162's Avatar
Originally Posted by jackpiner57 View Post
1 .Why would you do that?
2.And there was NO cupping on the front?
3. And you left them in? They cupped in 100 miles???
4. Is this with the DynaBeads out now?
5. OK, this part is a joke right?
1. I didn’t know they were still perfectly balance until after I put in the beads. Since the tires appeared to be at half life at ~10,000 miles I decided to try a mid-life rebalancing. Big Mistake.
2. It was a near perfect front...cept for the chicken strips.
3. Yes and Yes. Very minor cupping. It was easier to just put the weights back on. Things are good and perfect again. Except from the minor cup virbration past past 85MPH. I can live wit it.
4. No. See above.
5. Ah...nope. You’re welcomed to see the tires for yourself...if you were here. They appeared to be about half worn when I compared them to the New Wings. So I'll keep them on until ~16,000. I had planned on an 18,000 mile replacement (80% worn) until the failed Dyno Bead Experiment.
