NGK comparison - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 04-16-2019, 01:25 PM Thread Starter
NGK comparison
The stock plugs on the 2015 DL650A are NGK CR8EIA-9. Locally, the only ones I can find are NGK CR8EIA-10. According to NGK the only different is the gap. Stock plugs are 0.9mm whereas the CR8EIA-10 are 1.0mm. That's only a 1/10mm difference in gap, slightly more than a human hair. Would that make a noticeable difference?
Skinner is offline
post #2 of 6 Old 04-16-2019, 02:08 PM
Lrobby99's Avatar
There was a post earlier today on gapping Iridium plugs. The answer was do not touch the gap.
And the difference you note is no problem for this type of spark plug.
2018 1000XT, black. The Night's Watch. Givi engine bars, rear wheel mud guard, radiator screen. Givi V56 Litre Monokey topcase. Puig screen. Freeway Blaster horn. Speedohealer. SW Motech guards for R. brake reservoir, R. brake cylinder, exhaust pipe valve. Aprilia Tuono mirrors.
Lrobby99 is offline
post #3 of 6 Old 04-16-2019, 03:13 PM
locoblanco's Avatar
I'd be wary. The book says to check the gap with a wire gauge, spec is .8 to.9mm, (.031-.035"), and if not in spec, replace. Says never adjust gap. 1.0, while seemingly a small difference, is out of spec and could cause problems. Excessive voltage will be required to jump the gap, with possible damage to the coils resulting.
locoblanco is offline
post #4 of 6 Old 04-16-2019, 03:17 PM
Lrobby99's Avatar
I was looking at this.
https://www.stromtrooper.com/dl1000-...eix-plugs.html
But better to have real mechanics step in.
Lrobby99 is offline
post #5 of 6 Old 04-17-2019, 09:32 PM
BC Rider's Avatar
I couldn’t find them localy either. Amazon had them in packs of 4 at a much cheaper price than other online retailers in Canada. In the US a 4 pack is 36 bucks
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #6 of 6 Old 04-18-2019, 10:58 AM Thread Starter
I looked at clubplug.ca because their prices are usually very good, but they don't have the "9" either, just the "10". I'll check Amazon when the time comes.
Skinner is offline
Tire pressure gauge comparison LordSmoke Maintenance, Tech and Products. 1 07-21-2014 12:36 PM
Ratcheting Windshield question / comparison Stoopy DL1000A - 2014-2016 10 03-24-2014 01:01 PM
Anakee 2, Anakee 3, Conti Trail Attack tread Comparison jrozar Suspension and Tire Tech 14 07-08-2013 05:56 PM
Motorcycle Gas Mileage Comparison Chart XLonDL650 General V-Strom Discussion 14 06-05-2010 05:17 PM
