Speedometer sensor, front tire change - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 07-13-2009, 09:14 AM Thread Starter
moooz's Avatar
Hi all, I'm kinda new around this forum. I have an 07 DL 650. I Searched around but couldn't find my answer. I had a new front tire installed this past Saturday at my friendly neighborhood MC shop. I'm not sure if they installed my speedometer sensor correctly when my tire was changed. It doesn't quite look right to me. Does the little "male" tab on the fork leg fit into the "female" slot on the speedo sensor?
Anyone know of any photos posted anywhere of what it's supposed to look like? I don't want to go back to the shop and ask questions if it was done correctly. If it was put back together wrong, I have no problem with going back to the shop and explaining that it was done incorrect. Thanks everyone.
moooz is offline
post #2 of 3 Old 07-13-2009, 09:37 AM
Stromtrooper.com Sponsor
Satch's Avatar
The little "male tab on the fork leg" doesn't fit into a slot--the sensor bumps up against it so that it can't rotate beyond that point. It may look wrong to you because the angle of the sensor isn't parallel to the fork leg. If the speedo is working, it's probably ok.
:arrow: Follow the V-Strom Cache Adventure | See Where the Cache has Been | Play the Stromtrooper Picture Game | Play the Weekly Picture Game
Preferred V-Strom Model Nicknames: 02-12 DL1000 Vee, 2014+ DL1000 ABS Vee2, 04-11 DL650 Wee, 12-16 DL650 Wee2, 17+ DL650 Wee3
V-Stroms I've owned: Wee.07, Wee.11, Wee2.13. Currently Wee-less
Satch is offline
post #3 of 3 Old 07-13-2009, 10:10 AM Thread Starter
moooz's Avatar
Thanks for the quick reply. Upon closer examination the little "male" tab on the fork leg is sitting in front of the speedometer sensor against the sensor housing preventing it from rotating forward like you said. I think all is well, it just looked a little odd to me at first. Speedometer/odometer is working.
moooz is offline
