gear indicator acting up on 14 dl1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By moglink
post #1 of 6 Old 04-01-2019, 09:52 PM Thread Starter
Recently my gear indicator started acting up, usually when I'm in third gear. Sometimes it will show 4, sometimes it will flash between 3 & 4 and sometimes it will still read 4 when I downshift through 3rd to 2nd.
I'm wondering if there is anything simple I can do to fix it. Search results suggest cleaning or replacing a part that is inside (near clutch plates??) but that is beyond my skill level. The bike has 57k miles, runs great and I changed the oil when this started happening. That was about 400 miles ago. Been using Rotella T6 for the last 30k miles.
Any suggestions would be appreciated. I can take it to the shop but they are surely swamped at this time of year so that won't happen anytime soon.
Thanks in advance.
moglink is offline
post #2 of 6 Old 04-17-2019, 07:23 PM Thread Starter
Here's an update:
My gear indicator has been less spastic lately. I don't know where the sensor is or how it works but it seems like the fresh oil may have washed some dirt away; or maybe there was just moisture somewhere that has dried up. It's been a bit drier around here lately.
There seemed to be steady improvement after the oil change. It stopped flashing 3,4,3 after a short while and then showed the wrong gear less often. Today it didn't read wrong at all which is good news. The gear indicator is only a convenience but I'm accustomed to having it now so I plan to keep it. Hopefully it will continue to work until I take the bike in for some other service.
If there is any maintenance I should be doing on this, i.e. loose screws or connections I should be checking, I would like to hear about it. A simple explanation of how it works or where it is located would also be appreciated.
moglink is offline
post #3 of 6 Old 04-18-2019, 03:31 AM
Gert's Avatar
Similar to that reported in thread https://www.stromtrooper.com/dl1000a...tor-issue.html
Gert is offline
post #4 of 6 Old 04-18-2019, 02:26 PM Thread Starter
That helps. Thanks Gert
Gert likes this.
moglink is offline
post #5 of 6 Old 05-11-2019, 09:08 AM
Null 13's Avatar
Hey i had the same issue on my bike, the sensor was changed under warranty.
Been working fine ever since.
________
2014 VStrom 1000 Adv SE, because army bikes are more adv
Null 13 is online now
post #6 of 6 Old 05-11-2019, 01:01 PM
chirosyd's Avatar
Funny. I just brought my 2014 1000 in for an inspection and to correct the exact same problem with the gear indicator. I assume the dealer will change the sensor and all will be good. 40,000 miles and otherwise this bike has been just about flawless.
chirosyd is offline
DL1000, question about long distance comfort hrdkorsocerplyr DL1000 from 2002-2012 42 05-22-2019 04:48 PM
2018 Farkles and Great Upgrades for the DL650 and DL1000 SV Racing Parts SV Racing Parts 1 04-19-2018 11:26 AM
More Great Parts and Add On Upgrades for the DL650 and DL1000 SV Racing Parts SV Racing Parts 0 12-28-2017 12:23 PM
? about gear position sensor(03 dl1000) fearandcommonsense DL1000 from 2002-2012 14 10-09-2015 12:36 AM
My DL1000 only goes 80 MPH in second gear nujac General V-Strom Discussion 5 01-12-2014 10:10 PM
