Cleaning and lubing the chain. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 61 Old 04-20-2006, 07:29 PM
Tightline
I have cleaned and lubed my chain a few times since purchasing my bike. I have 700 miles on it now. My method for cleaning and lubing the chain is a family affair. I hold the bike on the side stand, my son rotates the back tire and my wife does the cleaning and lubing. Does anyone have a better method for just one person? I know a centerstand will make it easier, but aside from that, I'd like to hear what others are doing. I love my Wee Strom.
post #2 of 61 Old 04-20-2006, 08:01 PM
Night_Wolf's Avatar
Re: Cleaning and lubing the chain.
Order a LoobMan or similar product. That will keep the chain lubed. I haven't cleaned my chain yet and the bike is now over a year old. It does have 20,000 plus miles on the original chain so I must be doing something correctly 8)
Type @ Ya'll Later
Night_Wolf
2007 DL650abs Wee Strom
VSRI 1083/MIG 2625
A Newfie & Damm Proud Of It
Night_Wolf is offline
post #3 of 61 Old 04-20-2006, 08:44 PM
I reckon the only way to do it solo sans-centerstand is roll-lube, roll-lube, etc. My wife would tell me where to stick it if I asked her to help lube my chain so a centerstand is mandatory equipment on my bikes.
06 DL-650 - SilverBlue
05 DL-650 - red (RIP - watch your mirrors!)
TomG is offline
post #4 of 61 Old 04-20-2006, 09:01 PM
I have read on the net somewhere that a guy uses a "come-along" to lift the rear end- making the rear tire spin freely. I guess the bike was still stable but I don't know how. Center stand would be worth the money and a lot easier than lifting it with a come-along.
I do not have a centerstand and I never will, the Strom is heavy enough already. Slowly cleaning, lubing, turning, repeating isn't all that bad.
PS -- i don't spell or grammar check in most cases, but props if you can use my quick typing to debunk the factual foundation of my arguments!!
ononewheel is offline
post #5 of 61 Old 04-21-2006, 12:02 AM
Chain lubing and adjusting is the main reason I got a center stand with the bike. The weight is down low so it isn't an issue. I primarily use it when parked in the Bat Cave. Ride On.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #6 of 61 Old 04-21-2006, 10:08 AM
bjh
Does anyone out there use a race stand as opposed to the mounted centerstand for bike maintenance? I am considering getting one as it doesn't impact cornering while I ride but will hold the bike vertical with the rear wheel off the ground for maintaining it.
BJH
post #7 of 61 Old 04-21-2006, 10:24 AM
Albie's Avatar
This is what I use. http://www.motorcycleradar.com/quick_stand.htm
Cheaper and a heck of a lot lighter then a centerstand.
Albie
'05 DL 650
'06 DR 650
'07 GSXR 600
'07 KTM 450 EXC
'08 KTM 690 E
'09 KLX 250S
Albie is offline
post #8 of 61 Old 04-21-2006, 10:30 AM
I had used a piece of 4X4 cut to the appropriate length on one side and the side stand on the other. Recently I got a race stand (goes under the swing arm, push down, bike goes up) for $50, guy has a shop, had too many stands, sold it cheap instead of leaving it in a back room. Now I need some swingarm spools and I am set.
Albie, the quickstand looks good, I think on this board or the VStrom Forum someone made something like that using 3" PVC pipe.
Displaced Yooper
04 Blue DL650
ktrjc is offline
post #9 of 61 Old 04-21-2006, 06:17 PM
This may be straying OT but has anyone found or fabricated a stand to raise the front of the bike for front wheel/fork related projects?
TomG is offline
post #10 of 61 Old 04-22-2006, 06:18 AM
BJH,
I use a race stand with my Strom, I've had it for years, so I haven't bothered getting a centrestand. It works great! It's no problem at all to put the bike on it by yourself, even with loaded panniers and topbox. I pretty much park the bike that way every night, it makes a bit more room in the garage, and the cat likes to be able to sleep on the seat without sliding off the left side all the time.....
DL650 K5, Staintune pipe, topbox, Powerbronze bellypan, Givi E21's, Suzuki handguards
Barney is offline
