Shifter Return Spring - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
  • 1 Post By Brockie
  • 3 Post By JohnMidnight
  • 1 Post By Rolex
post #1 of 9 Old 02-28-2019, 05:30 PM Thread Starter
Soooo...
I'm going to be lubing the shifter joints tomorrow... but if that doesn't solve my shifter not popping back to "Neutral" for shifting, I was told it's internal, and the Parts Fiche screams at me its internal. How do I get to it? Googling what looks like what I want does not get me the pictures of the right bike......
Any help would be awesome.
Bike: Vee 2008 500 miles shy of 100K, and I want to get it there and over!
-JM
Newbie to VStroms, and their 2 cylinders.
But having fun learning all the new things!
JohnMidnight is offline
post #2 of 9 Old 02-28-2019, 06:47 PM
MAZ4ME is offline
post #3 of 9 Old 02-28-2019, 08:16 PM
Brockie's Avatar
Both springs, items #23 and #14, are internal and it would be unusual if the problem was there.
I would be disconnecting the lever to ensure that the Gear Shift Link Arm #25 returns freely. If it does then you need to clean and lube all moving parts back to the lever. If it does not I would remove the link arm to ensure that it is not rubbing against the engine case. Also check that the shaft #17 is not bent.
Hatchi likes this.
Brockie is offline
post #4 of 9 Old 03-01-2019, 12:16 AM
Unusual, but not impossible.
Ive had to replace but 1 shifter return spring due to breakage in 35+ years. I have replaced others while doing transmission repairs. As long as I was in there, and as inexpensive as the spring is, I didnt want to take a chance on going back in at a later date. Besides..springs dont get stronger with age and use.
MAZ4ME is offline
post #5 of 9 Old 03-01-2019, 03:49 PM Thread Starter
Now to clarify, I don't have to pull the engine out to do this, right? My first bike, any work on the shifter internals and transmission, required to pull the block out, which I don't have the means to do so, is this correct? ANd that behind the clutch is a plate I can open up and see the shifter rods? I was unable to get out to work on the bike, it was a split decision, stay home make some money, or go work on the bike >.>
-JM
post #6 of 9 Old 03-03-2019, 02:11 AM
Rolex's Avatar
I had one go bad on one of my DT175's I was surprised to find the spring was OK but the pin the spring worked off had snapped clean off, there must have been some abuse on that leaver.
Sorry I have never opened the covers of my Stroms but every other bike that I have owned only required removing the clutch cover and the clutch basket to get at the spring. ????
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #7 of 9 Old 03-03-2019, 06:45 AM
Brockie's Avatar
You would need to remove the engine and split the cases for a total tear down.
Brockie is offline
post #8 of 9 Old 03-11-2019, 01:51 AM Thread Starter
Seems it was the external shifter components. As nothing internal looked out of wack.
The joints cleaned and lubbed, shifter works as it should now. Thanms for the assists
Sent from my SM-G973U using Tapatalk
Spec, Brockie and WildDoktor like this.
-JM
post #9 of 9 Old 03-11-2019, 02:56 PM
Rolex's Avatar
Love good news.
The shifter is often taken for granted but a little lube works wonders, if your gear leaver needs lube your brake leaver will too.
MAZ4ME likes this.
2014 V2, Snoopy
Rolex is offline
Fork spring upgrade on the cheap; watch out, we're doing math! whodat Suspension and Tire Tech 13 12-17-2013 10:50 AM
REAR spring rate: WHAT IS RIGHT!?!? SWriverstone Suspension and Tire Tech 20 11-25-2013 10:01 PM
goldwing pegs, RR lowering kit, shifter extender munsterlander Maintenance, Tech and Products. 4 07-02-2013 02:49 PM
Advice? - Shops can't disassemble shock spring? marku General V-Strom Discussion 21 02-23-2013 01:22 PM
