Weird Oil Drain Plug - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 19 Old 01-30-2019, 12:09 AM Thread Starter
Location: Ann Arbor, MI and San Miguel de Allende, Mexico
So this happened...
I did my first oil change on my new-to-me in Mexico 2014 Vstrom 1K. I noticed the plug was a little stiff coming out, sort of like someone put blue locktite on it. But when I got the plug out, it was obvious that this isn't the stock plug.
Ugly, isn't it?
My theory is that this is some sort of generic self-tapping drain plug replacement for when a gorilla over-torques the plug and damages the threads in the oil sump.
I had a stock drain plug which I tried in the apparently partially now reamed out hole just for curiousity -- it was almost all the way in before the threads caught and I could only get about half a turn before it bottomed out -- without the crush washer. Nope -- that's not going to work. I put the ugly one that came out back in and tightened it just enough to barely seat against the new crush washer.
I've never come across one of these before -have any of you?.
Am I right and that's what this thing is?
Anyone have any experience with these things? Is this a reasonable fix and can I expect it to hold up over time or will I eventually need a better solution which I assume would be something like a timesert or helicoil? (It may be a challenge finding someone who has experience doing that down here.)
Sorry for the fuzzy picture -- my iPhone apparently couldn't stand looking at it either so it wouldn't focus sharply!
Thanks for any insight,
Vinnie
Lrobby99 likes this.
Currenv is offline
post #2 of 19 Old 01-30-2019, 12:35 AM
That's apparently an oversized self tapping oil drain plug. A better fix would be something like a Time Sert oil drain plug repair. Do some searching to find the correct kit. I'm not sure if the kit will allow you to use the original plug.
locoblanco likes this.
Hatchi is offline
post #3 of 19 Old 01-30-2019, 08:17 AM
David Waldo's Avatar
That looks like a bolt from a reloading die that holds the decapping pin. Odd place for it.
David Waldo is offline
post #4 of 19 Old 01-30-2019, 09:46 AM
D.T.'s Avatar
That's an unpleasant surprise for a new to you bike.
Dorman has a few options.
https://www.dormanproducts.com/gsear...il+drain+plugs
MrF likes this.
D.T. is offline
post #5 of 19 Old 01-30-2019, 09:54 AM
MrF
MrF's Avatar
Is it solid? Most of those have a hole all the way through. https://www.precisionreloading.com/c...!l=LE&i=SD2151
Doorman and eco plug both make somewhat different solutions for stripped oil drain holes.
David Waldo likes this.
2016 V-Strom 650
MrF is offline
post #6 of 19 Old 01-30-2019, 10:04 AM
locoblanco's Avatar
Best is some type of permanent repair, but there are expanding rubber plugs to get you by in the short term.
locoblanco is offline
post #7 of 19 Old 01-30-2019, 10:09 AM
Yeah, need my second cup of coffee......brain fog
post #8 of 19 Old 01-30-2019, 12:21 PM
larolco's Avatar
It looks like a self-tapping drain bolt, as you suspected.
On the head there should be a number printed, either a 1, 2, or 3. That tells you how much oversized it is. They increase in size by number. Once you hit 3, you have to do the time-sert thing, or something similar.
I'd never seen this before I resurrected my buddy's CB750 last summer. It had one installed and needed repairing again.
DRZ400SK17
larolco is offline
post #9 of 19 Old 01-30-2019, 01:16 PM
On the other hand, if it is doing the job of plugging the drain hole, why not leave well enough alone?
Rick505 and Motorpsychology like this.
post #10 of 19 Old 01-30-2019, 01:59 PM
Yes, it IS a self-tapping drain plug. Ive seen..and dealt with many of them.
As suggested above, the Time-sert repair is the best permanent repair. The tool set makes sure the threads for the insert are installed at an exact 90-drgeree angle to the thread bore surface. The Time-sert will not come out when removing the plug like some have done. Ive 2 Time sert sets, one for 14mm drain plugs and another for 10mm spark plug threads. About $90 each.
Your oil drain plug dilemma is a a poster child for advocating the use of a torque wrench.
As for a possible problem with a self-tapping drain plug: Ive seen more than a few tht with repeated removal, will strip out the threads again until you need the next oversize self-tapping plug. Unfortunately the Vstrom V-Twin drain plug threads are in the crankcase itself instead of a replaceable oil pan. A 1-time permanent repair is your best bet.
MAZ4ME is offline
Eco plug (oil drain plug) test roughroad DL650A - 2012-2016 22 03-04-2019 10:26 AM
Oil drain plug gasket removal FRIDAY BIKE Maintenance How-to 30 04-18-2017 04:32 PM
Help- What drain plug is this? mikejohnson DL650A - 2012-2016 8 08-18-2015 03:07 PM
Screwed up a easy oil change..now need a part number for the oil drain plug Mastery V-Strom Service and Maintenance Questions and Discussions 22 07-23-2014 05:55 PM
Replace the oil drain plug washer... really? Prime General V-Strom Discussion 25 05-11-2013 11:40 AM
