Clutch replacement symptons? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 14 Old 01-24-2019, 07:45 AM Thread Starter
Hmm
Hmm's Avatar
Could anyone tell me what symptoms will show when a person is approaching a clutch rebuild? I have a 2008 Wee with 23K on the odo.
Bill
I been down around Houston Texas where the sun shines most of the time.
2008 Wee current
2014 Spyder RT LTD current
Past - Yamaha 850, Honda Nighthawk 700, Honda GL1200, Yamaha FJ1200, Suzuki Bandit 1200, Honda GL1800
Hmm is offline
post #2 of 14 Old 01-24-2019, 08:30 AM
what are you experiencing now that makes you think you might need a rebuild? I've been told that these clutch plates are going to last a loooooong time, so definitions of "clutch rebuild" will vary person to person. If you are experiencing shaking, chudder, jerky release, bronco takes-off from a stop, from your clutch as the mileage on the ODO increases, I'd advise you email or call Terry at Werks Parts -- he's on this forum as RealShelby. My 08 Vee was at about that mileage and I simply could not stand it any longer. Nothing I did could smooth it out. I talked with and emailed Terry. Best money spent on anything on my bike to have him rework the bearing surfaces, etc... on my clutch basket.
Yarz1 is offline
post #3 of 14 Old 01-24-2019, 09:54 AM
Fox
Fox's Avatar
Needing clutch work at 23k miles would be very unusual. If you do a lot of stop and go riding, you'll need to adjust the play pretty often.
I have 119k miles on my original clutch, and it doesn't noticeably slip.
Fox is offline
post #4 of 14 Old 01-24-2019, 09:59 AM
I have well over 20,000 miles on my 2012 DL 650. Clutch has never been adjusted since I set the lever freeplay when new.
It is easy to screw up adjusting these clutches, meaning they do not have adequate play in the mechanism. That can burn up clutch frictions.
If you notice clutch slipping a moment when shifting gears, or engine rpm flares up when going wide open throttle that is a sign of clutch issues. Especially in 4th, 5th, and 6th gear.
realshelby is offline
post #5 of 14 Old 01-24-2019, 01:12 PM
locoblanco's Avatar
The clutch release mechanism on that model is behind the sprocket cover, easy access. Same as the early SVs. Go to SVRider.com and look for Andy Auger's Clutch Mantra, best write up I've ever seen for the adjustment procedure.
locoblanco is offline
post #6 of 14 Old 01-24-2019, 02:37 PM
Fox
Fox's Avatar
It's worth noting that the 2012+ 650s use a very different mechanism to disengage the clutch. https://www.bikebandit.com/oem-parts...586&sch=508028
The previous mechanism is much sloppier and prone to wear.
Fox is offline
post #7 of 14 Old 01-24-2019, 03:55 PM
True, they are different. So I will tell you that we put 29,000 miles on the 2004 DL 650 and never adjusted the clutch linkage and never had any issue at all with the feel or actuation of the clutch!
post #8 of 14 Old 01-24-2019, 04:30 PM
blaustrom's Avatar
As a long shot, is your clutch cable by any chance starting to unravel at the upper nipple. That will make you think something is up with the clutch. Why do I know? If all is well when you inspect make sure that rotating nipple inserted in the lever is well lubricated!
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #9 of 14 Old 01-24-2019, 04:59 PM
V-Tom's Avatar
We might be able to give you actual useful advice if you tell us what makes you think you have issues.
My 2006 DL650 has the original clutch when I stopped riding it with over 125,000 miels.
Issues I had were:
-Broken Clutch Cable
-Arm on adjuster (inside front sprocket cover) came loose when spot weld broke making me think clutch was a problem
-Bent clutch levers from falling over causing various issues.
But never an issue with the clutch itself.
..Tom
Gert and Brockie like this.
2015 DL1000 New July 2015 180,000+ km, 112,000 miles.
SMIDSY detailed report.
V-Tom is offline
post #10 of 14 Old 01-25-2019, 01:49 AM
Or someone put car oil in the bike ?.
The clutch my my gen 1 DL 650 lasted 80,000k's with horrific abuse, gen 2 130,000k's though I did have to dive in and adjust the clutch free play on that one @~20,000k's.
I'll concede it's not obvious initially, lack of acceleration, particularly lack of punch out of the corners without any other issues is the giveaway.
If you do refresh it, new springs matter even more than new friction plates.
Oh, and it'll be a bit of a bastard in stop-go traffic until everything beds in (About a month). They usually won't change gear while stopped for a 1000k's or so.
PeteW is online now
Complete clutch replacement, what do I need? socially stunted DL650 and DL650A - 2004 to 2011 7 11-07-2016 09:06 PM
Clutch replacement Boit4852 V-Strom Modifications and Performance 15 10-26-2013 02:35 AM
Clutch cable fraying - automatic replacement? mtnfsh General V-Strom Discussion 11 06-01-2012 05:58 AM
clutch basket replacement vstromsteve DL1000 from 2002-2012 37 08-28-2009 12:55 AM
Clutch Cable Replacement madstrom V-Strom Service and Maintenance Questions and Discussions 5 01-16-2008 09:51 AM
