What complete fuel pump assemblies will fits k9 vstrom 650? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 01-06-2019, 12:02 PM Thread Starter
BlueStrom2005's Avatar
I've bought a 2nd Vstrom 650 - K9 aka 2009 that previous owner worked on a few things. So far anything that PO worked on needs to be fixed correctly.
The fuel pump is one of the items and the body may be damaged beyond use. Thus I wonder what complete fuel pump assemblies will fit this bike. For example can the DL1000 pump from some years work in this bike?
Thanks in advance for any info.
BlueStrom2005 is offline
post #2 of 3 Old 01-06-2019, 03:54 PM
nvr2old's Avatar
I believe the 2007-11 are the same. The 1000 2002-12 is the same or similar to the 04-06 650.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #3 of 3 Old 01-07-2019, 08:39 AM Thread Starter
I think I saw an older post by GreyWolf that suggested a 2004- 2006 DL650 fuel pump would fit the the 2007 to 2009 DL650 and be good for the high pressure filter bypass. (As in pickup a 04-06 fuel pump to use in the 07-2011 DL650 to use for the bypass as the newer pump was not as suitable for the bypass) To continue on that thought I believe I also read that the early DL1000 pumps would fit the early DL650's .
If I understood correctly that would seem to mean that the DL650 fuel pumps from 2004 to 2011 will physically fit, work, and be swap-able between those years.
Also, it seems to suggest that some of the DL1000's complete pump assemblies may fit as well.
I'm just trying to sort out what the Pool of good used fuel pumps might be to use in a 2009 DL650.
Fuel pump diagnostic help TK421 DL650 and DL650A - 2004 to 2011 16 03-25-2017 03:09 PM
Fuel Pump Gremlins? Scootertrash in Paradise DL650 and DL650A - 2004 to 2011 8 03-06-2017 07:11 PM
Urgent: V-Strom Fuel Pump not Working Dev DL650 and DL650A - 2004 to 2011 35 07-09-2015 07:42 PM
Whistling fuel pump :) Weehemoth DL650 and DL650A - 2004 to 2011 10 03-23-2015 10:56 AM
DL650 Felco Fuel Pump madstrom DL650 and DL650A - 2004 to 2011 6 07-27-2013 06:21 PM
