strange engine problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
  • 1 Post By strominateacup
  • 2 Post By marcham
  • 1 Post By justjefffornow
  • 1 Post By Rolex
post #1 of 10 Old 12-29-2018, 01:16 AM Thread Starter
hello all, just signed up. seeking help for a specific problem. having lurked here many times i have seen numerous issues solved so thought i'd give it a shot. back story: i have an 08 wee with 34,000 miles. i bought it 2 yrs ago with 3400 miles on it & it has been a delight until recently. earlier this year we bought a '17 versys 1000. the wee sat for about 2 weeks for obvious reasons. when i wheeled it out to ride it again i got a crank/no start. cranked strong, just would not fire. bear in mind this is my daily commuter so i was more than a little surprised. spark, yes. fuel, yes. wth? finally gave it a shot of starting fluid, it lit right off, ran for a few seconds & died. this is where it gets interesting. i hit the button again, it started, ran for a few seconds and seemed like it wanted to die again, enough that i hit the button while it was still running, although barely. engine made a clattering noise like you would expect the starter to do when engaging a running engine. i shut it off & restarted it, fired right up & idled normally. the issue is that the engine now vibrates in the 4-6000 rpm range ever so slightly where as before it was wonderfully smooth. does not seem to lack power, just vibrates. i'm thinking the balance shaft is now out of time but i'm having a hard time finding any info on this. i did take it to a shop as it had been scheduled for a valve adjustment, he said it didn't need one. so. any ideas????? any response would be much appreciated. Jeff
justjefffornow is offline
post #2 of 10 Old 12-29-2018, 01:24 AM
strominateacup's Avatar
I don't know what it is, but I don't think its the balance shaft. As far as I know there's no 90 degree V twin with a balance shaft.
V-Tom likes this.
There are holes in the sky where the rain gets in,
and the holes are very small, that's why rain is thin.
Spike Milligan.
strominateacup is offline
post #3 of 10 Old 12-29-2018, 02:34 AM
Charlie1982's Avatar
Is it possible that the fuel in your tank started to go bad in the time it was sitting still? That could make it start & run rough.
Charlie1982 is offline
post #4 of 10 Old 12-29-2018, 02:50 AM
marcham's Avatar
1. Check air filter.
2. Check that all 4 plugs are properly torked and harnesses secured
3. Dump gas and fill with fresh
Try running it again. Confirm battery voltage is above 13.5V while running.
Sent from my SM-T590 using Tapatalk
Big B and richlandrick like this.
2015 VSTROM 650 X ABS EXP
marcham is offline
post #5 of 10 Old 12-29-2018, 09:04 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
If it were a 1000, vibration at 3K to 4K would indicate clutch basket issues.
Is the vibration present when the bike is sitting still land revving the engine or just while riding?
I know this sounds strange, but be sure to check the connection at the battery. Corrosion or loose connections can e decrease the ability of the bike to charge the battery and make power available for spark plugs.
At 34K miles you might be ready for new plugs.
richlandrick is offline
post #6 of 10 Old 12-29-2018, 07:59 PM Thread Starter
i replaced the plugs & air filter at 25,000 miles. the fuel was only 2 weeks old, remember this is my daily ride. the vibration is only between 3 & 5000, more pronounced at the higher side. battery is fairly new & it was cranking normally, just would not start. the stator on this bike failed at 20,000 miles, the new one is charging 13.8 or better. don't remember where i got the idea about the balance shaft. it was in the back of my mind just like a lot of other things & i can't figure out how they got there.
notacop likes this.
post #7 of 10 Old 12-30-2018, 09:50 AM
" it was in the back of my mind just like a lot of other things & i can't figure out how they got there."
That only gets worse with age! The mind becomes a repository of all sorts. Until you get really old then the important stuff disappears.
post #8 of 10 Old 12-30-2018, 11:11 AM
RestoRider2017's Avatar
Location: Apopka Florida NW of Orlando near a twist in the road and a hill on the horizon...
I guess the best thing to add is ; forgetaboutit Problem solved for now.
2017 DL 650 , Shad 23 side bags, Givi crash bars, 32 watt LED driving lights ,
Goldwing pegs, silver front fender, Lazer cut aluminum Chain guard, Madstad 20" windshield
light smoke tint , Blu/blk Driven Racing Billet bar ends.
"any comments made on this forum are purely for amusement purposes only.
not to be confused with actual knowledge"
RestoRider2017 is offline
post #9 of 10 Old 12-30-2018, 04:11 PM
Rolex's Avatar
I would check your throttle bodies are still in place on the intakes.
When you use starter fluid the fluid will often fire at the wrong time and that is the clattering noise you heard, it's often called dieseling.
This can cause back pressure in the inlet manifold and blow the bodies off.
blaustrom likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #10 of 10 Old 12-30-2018, 10:37 PM Thread Starter
worth a try, i'm gonna have to take it apart no matter what. i would have thought though that the engine would hardly run at all if that was the case. i'll let you know. thanks, Jeff
v-strom 650 engine idle RPM, fuel eco. and stalling problems Gaszton DL650 and DL650A - 2004 to 2011 4 10-31-2015 03:14 PM
Pic of used bike engine - potential problem? DownOnTheFarm V-Curious 13 03-13-2013 10:56 PM
Need help with carbeurated engine problem bobosmite Maintenance, Tech and Products. 10 11-25-2010 11:44 PM
surging/correct mixture rmx250 Feedback to Suzuki 19 08-14-2010 06:11 AM
strange happenings with my V ncvulcanrider DL1000 from 2002-2012 21 03-30-2008 09:59 PM
