ABS question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 12-27-2018, 05:21 PM Thread Starter
mystrom's Avatar
ABS question
Hi all,
Hope your holidaze are going well,
I have a 2011 DL650ABS Strom and I need to replace my rear wheel ABS sensor. My question is, where is the connector? The dealer thinks I'll need to remove the gas tank to get at the connector, does anyone know if that's true? Any and all info is greatly appreciated.
Happy new year to all,
Dave
mystrom is offline
post #2 of 4 Old 12-27-2018, 05:50 PM
dmfdmf's Avatar
I think that is correct. I just checked on my Gen2 L4 650 and the ABS sensor wire runs up the swing arm on the right hand side of the bike and connects to a bundle of wires below the radiator overflow tank. Not really enough room to get to it without getting other stuff out of the way first. It looks like you'd need to remove the gas tank and the overflow tank and bracket. I'm pretty sure its the same on the Gen1 Wee.
That said, what makes them think the ABS sensor is bad? What are the symptoms? It is fairly unusual for that part to fail but it does happen. Ask them what happens when they replace it and it doesn't fix the problem.
Next Up: ?
dmfdmf is offline
post #3 of 4 Old 12-28-2018, 10:47 AM Thread Starter
mystrom's Avatar
Hey dmfdmf, the shop hooked up my bike to their "Suzuki" computer thing and it spit out codes for defective ABS controller and rear wheel sensor. He then cleared the codes and took the bike for a ride. He confirmed the ABS is not working. Then he hooked it backed up to the diagnostic box again and the only code that came up was for the wheel sensor.
He thinks the first time when he got the code for the controller it was because of the bad wheel sensor. He says when he gets the sensor he'll hook it up to see if the codes clear.
I hope its not the controller, its crazy expensive. I told him to first check all the connectors to make sure they're clean and tight....To be continued
Thanks for your input,
Dave
(riding without ABS, but I get caught in the rain often enough I'd rather have it)
mystrom is offline
post #4 of 4 Old 12-28-2018, 03:02 PM
The only issues I remember reading about im the last 5 years have been sensors misspositioned or damaged during tire replacement.
Hatchi is offline
Question from the electrically challenged Wee Willy Winky General V-Strom Discussion 5 01-13-2015 04:21 PM
Tire Question? But not which tire question VStromThom DL1000 from 2002-2012 11 03-23-2014 10:51 AM
wiring a ground question chetc General V-Strom Discussion 7 11-16-2012 05:38 PM
DL1000 Chain Question (ordering question) shawnubis DL1000 from 2002-2012 5 11-16-2012 09:31 AM
Dirt, gravel and mud question TheWall DL650 and DL650A - 2004 to 2011 19 06-02-2012 10:11 AM
