front wheel removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 04-19-2006, 11:39 AM Thread Starter
805gregg's Avatar
front wheel removal
Anyone have the tool for removing your front wheel, 19mm hex or special tool? Is it necessary?
805gregg is offline
post #2 of 11 Old 04-19-2006, 12:45 PM
The DL1000 is 19mm and the 650 needs a 12mm. Some folks use a bolt of the proper head size and a couple of jam nuts.
post #3 of 11 Old 04-19-2006, 02:55 PM
Augie
The crap steel in the toolkit will not deal with it. I too recommend the bolt and jamnut methods.
post #4 of 11 Old 04-19-2006, 04:06 PM
kurt1305
A 5/8" spark plug socket just happens to have a hex on the top side close to 19mm. On some of them you can insert an extension backwards through the socket and use it as an axel key. This tip saved my butt in the middle of nowhere.
post #5 of 11 Old 04-19-2006, 07:06 PM Thread Starter
805gregg's Avatar
Thanks guys, I checked my tool kit it doesn't seem to have anything to remove the front wheel, whats up with that, I guess my tire is supposed to last forever. I made one out of a bolt with a 19 mm head.
805gregg is offline
post #6 of 11 Old 04-20-2006, 11:16 AM
You can order a 19mm hex socket from mcmaster.com for about $12, IIRC.
06 DL-650 - SilverBlue
05 DL-650 - red (RIP - watch your mirrors!)
TomG is offline
post #7 of 11 Old 08-10-2006, 10:31 AM
Aerostitch has one for $27, Fits 4 different sizes (in my case it will also fit my 12GS.
http://www.aerostich.com/catalog/US/...l-p-17557.html
07 DL1000 (in the UK)
DL100 w/ Ural sidecar (in Socal)
RoadGlide
R1200GS
Road King
GoldWing
Dyna Superglide
Streetrod
Paladin is offline
post #8 of 11 Old 08-11-2006, 08:07 AM
Send a message via MSN to bycharlie
Rear wheel Removal tool
This forum just answered 1/2 of my doubt... now; can anyone tell me the size for the rear wheel tool for the Vee 1000? 8)
bycharlie is offline
post #9 of 11 Old 08-11-2006, 08:19 AM
Raindog's Avatar
Re: Rear wheel Removal tool
you'll need a 24mm key..
Roar Bjørndal-Rasmussen
Eidsvoll, Norway
'01 gsx600f, sold in '06 and replaced by...
'04 DL1000 V-Strom
Raindog is offline
post #10 of 11 Old 08-11-2006, 10:07 AM
Gilk51's Avatar
A friend of mine bought one of these and it broke when changing the wheel on his 1000. I don't recommend it since it is made of aluminum. The one from McMaster-Carr is a good tool - probably better in the long run.
.......Chuck
blue '04 DL-650
dark cherry '07 FJR
AARP member!
Gilk51 is offline
