Clutch lever freeplay and clutch wear - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-07-2009, 02:18 PM Thread Starter
wayner's Avatar
Question Clutch lever freeplay and clutch wear
Guess Im hard on the clutch (2400Miles) If Im already adjusting clutch.
Just changed oil and thought maybe I had used wrong oil but just checked
and OK.
Operator Error I guess.
Kind of acts like the dry clutch on my BMW and i never did get used to it.
Any other ideas?
Thanks in advance
Ride Safe
Wayne
DL650
DR650
wayner is offline
post #2 of 6 Old 07-07-2009, 02:51 PM
Just adjusted mine too, at 2500. Cables stretch, I didn't think much of it. Is it that abnormal?
Mike
2009 [COLOR="DarkOrange"][B]Orange[/B][/COLOR] Wee
[COLOR="DarkOrange"][B]Orange[/B][/COLOR] Wee Club #51
skyydiver is offline
post #3 of 6 Old 07-07-2009, 02:56 PM Thread Starter
wayner's Avatar
Smile
I have read a lot about adjusting at 4000 per manual so thought I would
ask since I am adj early. Just going to adj and forget about it till next time.
Thanks for info
Ride Safe
Wayne
DL650
DR650
wayner is offline
post #4 of 6 Old 07-07-2009, 05:13 PM
randyo's Avatar
remember that, the the cable adjusters are not how you adjust the clutch, the clutch adjustment is the locknut/screw (pushrod) under the sprocket cover, fiddling with the cable without first adjusting the clutch is not the way to adjust the clutch
fwiw, the fibre clutch plates on my SV650 lasted 102,000 before they needed replacing, springs & steel plates are still original @ 135k
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #5 of 6 Old 07-08-2009, 02:04 AM Thread Starter
wayner's Avatar
Thanks
https://www.stromtrooper.com/forums/s...ad.php?t=41984
Ride Safe
Wayne
DL650
DR650
wayner is offline
post #6 of 6 Old 07-08-2009, 12:42 PM
silverstrom's Avatar
The clutch cable will stretch over the first few thousand miles, just like the chain. Once the initial adjustments are made you'll have no problems for a while. It's all very normal. As has been mentioned arleady, make sure you make the adjustment at the bottom end first.
This thread might be useful https://www.stromtrooper.com/forums/s...tch+adjustment
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
silverstrom is offline
