Clutch adj question DL650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 07-07-2009, 01:33 PM Thread Starter
wayner's Avatar
After removing the sprocket cover per manuals instructions...the next paragraph
says "loosen the lock-nut (3) and turn out adj screw (4) 2-3 rotations.
Then in the very next sentence it calls the the adj screw (3)
Makes doing the operation pretty confusing...even tho it should be simple operation.
Do I need more coffee or am I reading it wrong?
What Goes??
Ride Safe
Wayne
DL650
DR650
wayner is offline
post #2 of 4 Old 07-07-2009, 01:50 PM
I rock at logic
LucasD's Avatar
Just a typo. No additional coffee required.
Should read:
Loosen the lock-nut 3 and turn out the adjusting screw 4 two or three rotations.
From that position, slowly turn the adjuster screw 4 in until it stops.
Turn the adjuster screw 4 out 1/4 rotation, and tighten the lock-nut 3.
2006 DL650
"We've done four already, but now we're steady and then they went one, two, three, four..."
LucasD is offline
post #3 of 4 Old 07-07-2009, 01:50 PM
Typos for sure. In the picture, the adjuster screw is 4 and the lock nut is 3.
post #4 of 4 Old 07-07-2009, 01:58 PM Thread Starter
wayner's Avatar
Thumbs up
Thanks guys for the clarification...I knew from prev exp that the center screw
had to be the adj and outer the lock but wanted to make sure before going to the
garage.
Seems Im killing the bike and having to slip clutch to get going other wise im killing it.
Hope this is the fix
Ride Safe
Wayne
DL650
DR650
wayner is offline
