Bike "Jumps" when starting on cold days - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 21 Old 11-19-2018, 01:01 PM Thread Starter
newride's Avatar
When I first start the bike in the morning on cold days, it tries to jump forward. I have to hold it in place using both legs, and the starter barely turns the motor. By the time I hit the end of the driveway, everything feels normal, and when I start it throughout the day, there is nothing out of the ordinary. I assume that the oil is a little thick because of the cold and is causing my clutch to behave badly, but I don't know if this is normal, or something I should worry about, or if there is anything I can do about it anyway.
newride is offline
post #2 of 21 Old 11-19-2018, 01:10 PM
V-Tom's Avatar
Thinner oil would likely help (no talking oil here though that is only allowed in the Big Oil thread.)
If we knew what bike you had we might be able to suggest clutch adjustment tips.
..Tom
2015 DL1000 New July 2015 180,000+ km, 112,000 miles.
SMIDSY detailed report.
V-Tom is offline
post #3 of 21 Old 11-19-2018, 01:10 PM
BC Rider's Avatar
Thick cold oil between the clutch plates will transfer power even with the clutch lever pulled. Time for an oil change to a lighter grade. Synth perhaps. Also try starting in neutral rather than just pulling in the clutch lever in gear.
Big B, Willie, VSrider and 1 others like this.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #4 of 21 Old 11-19-2018, 01:22 PM
No, what you describe is not "normal". It is a sign your clutch isn't releasing properly. Cold weather can make this seem worse. Starting the bike in gear with it acting like is it could result in some unintended results! I would start the bike in neutral, then pull in the clutch and put it in first. Which could still result in it lurching forward if the clutch isn't releasing. If a 650 make sure it is adjusted properly. On a 1000 it likely means either there is air in the clutch hydraulic system or the clutch slave cylinder is needing rebuilt or replaced.
realshelby is offline
post #5 of 21 Old 11-19-2018, 01:33 PM
Perfectly normal for a wet clutch! Every bike I have ever owned dragged it's clutch on initial start in cold weather. No adjustments needed. As mentioned, start bike in neutral, (you should be doing this anyway) and you could try using an oil with a lower first number.
scab likes this.
Willie is offline
post #6 of 21 Old 11-19-2018, 02:48 PM
Highwayman2016's Avatar
Mine drags a little too. Put it in neutral and let it run for a little while. I use a 10W40 oil in Las Vegas.
2014 650 Strom
Highwayman2016 is offline
post #7 of 21 Old 11-19-2018, 03:07 PM
K9 Wee's Avatar
Yup, normal for the Wee...starting in Neutral is always a good move. Also, move bike backwards after starting and clutch in/out before placing in 1st gear. That should prevent the "lurch" as it should force the clutch plates to unstick from each other.
No oil conversations but in the Big Oil Thread but because I have the Bridgestone BattleWings (2nd set) my clutch no longer does this!
______________________
2009 Orange DL650
SW Motech Rally Crashbars, Skidplate & Centerstand
Givi e22L Sidecases
Shad 33L Topcase
Wolfman 40L Waterproof Duffel
Givi Tanklock 25L Tankbag
Techiwik Long Underwear
1978 Honda CB550K-Sold
K9 Wee is offline
post #8 of 21 Old 11-19-2018, 03:12 PM
I all ways start in Netural unless kill it in traffic. Being a old fart of 72 and a bad knee from a kicker gear tooth braking in my late 20s on my shovel chopper it happens.If below 30 I start and let warm while I put on last layer of gear .
Old Time Rider is offline
post #9 of 21 Old 11-19-2018, 03:18 PM
...and hold the front brake while starting. Even if it wants to lurch, it cannot go anywhere.
notacop, K9 Wee and scab like this.
BackPacker is offline
post #10 of 21 Old 11-19-2018, 03:36 PM
I will stand by my statement that this is NOT normal!
Yes, a wet clutch can stick but every one I have been around would break loose before it got as bad as described above. Pushing a bike around in gear with the clutch in when cold will be a struggle. But nothing I have seen has ever required me to fight holding it ( I would hope a bit of front brake was in use also....) to the point it was pulling the bike along with the starter motor!
Cold Weather Stops my bike sdmvstrom Maintenance, Tech and Products. 3 09-16-2016 10:25 PM
My Day @ Barber Motorsport ChiGuy64 Riding Proficiency 12 06-04-2013 08:39 PM
Hard starting slow Idle when cold. T-ville Trooper DL650 and DL650A - 2004 to 2011 6 04-05-2013 01:30 PM
Loose electrical connection on clutch side is making starting the bike difficult arooni Maintenance, Tech and Products. 1 01-30-2013 01:16 PM
