High Mileage 2007 Wee - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 16 Old 11-02-2018, 02:12 PM Thread Starter
I bought a 2007 DL650 with 49k on it. It ran good , but I knew it needed lots of love. I didn't pay much, so I have been going through it. So far I have, rebuild calipers,new rotors, new pads, new rad, new bearings front and rear, tires, new fork seals, plugs, starter, chain , both sprockets, and of course all associated fulids. I'm looking for any other advise on what else I should address that may not be obvious. This bike is going on a 2500 miles trip around Baja this spring.
Looking forward to hearing your thoughts
CapMorgan is offline
post #2 of 16 Old 11-02-2018, 03:06 PM
blaustrom's Avatar
Welcome! That is really not "high mileage". Once you have doubled it than maybe.
You have done a lot already. How about Valve clearance check? And did you change the coolant? Best combined with a coolant change. Remove the radiator, makes access to the front cylinder much easier.
Whilst all is off, check all electrical connectors for oxidation, clean if necessary and re-assemble with dielectric grease. Check the starter switch for corrosion, especially if there is no headlight relay kit installed. Get the kit if not installed.
Check tank and fuel pump pre-filter. Any crud accumulated in the sump, any rust? Do the fuel flow test.
… Get the service and repair manual and check to see what I missed.
Suspension: I would get ricor intiminators for the forks and have someone rebuild the OEM rear shock. Both will transform the bike.
fear_factory84 likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #3 of 16 Old 11-02-2018, 06:03 PM
The radiator needed replacing? Here are a few more things:
Battery YTX12-BS Yuasa (best)
Air cleaner
acf50 in all electrical connectors above radiator
+1 on head light relay
Hatchi is offline
post #4 of 16 Old 11-02-2018, 06:14 PM Thread Starter
The Rad was corroded on the outside and fairly beat, so... Just replaced the battery, forgot to put it on the list. Where can I find the headlight relay kit. Any suggestion on a volt meter ?
post #5 of 16 Old 11-02-2018, 08:23 PM
Highwayman2016's Avatar
Eastern Beaver has the headlight relay kit. https://www.easternbeaver.com/
2014 650 Strom
Highwayman2016 is offline
post #6 of 16 Old 11-02-2018, 08:56 PM
"High mileage"......LMFAO!!!!!
post #7 of 16 Old 11-02-2018, 09:12 PM
Brockie's Avatar
Eastern Beaver H4 Dual Headlight Relay Kit
https://easternbeaver.com/Main/Bike_...om/vstrom.html
Hatchi likes this.
Brockie is offline
post #8 of 16 Old 11-02-2018, 09:59 PM
Brockie's Avatar
My DL650 power socket gets its power from the heated grips connector which is powered by the key. See the thread https://www.stromtrooper.com/dl650-d...-location.html It is under the tank/airbox and just behind the radiator. https://www.stromtrooper.com/dl650-d...-location.html
I wired a voltmeter in before the socket for my GPS/phone whatever. Some have commented that the plug works itself loose over bumps but the one I purchased has a "lock" in it with a small twist to the right once the plug is inserted.
You can find the plug and voltmeter I used here:
https://www.jaycar.com.au/marine-gra...ckets/p/PS2020
https://www.ebay.com/itm/DC-12V-24V-...-/382581384207
Brockie is offline
post #9 of 16 Old 11-02-2018, 10:53 PM
Brockie......what in the world is that HUGE sticker on your dash? 😉
Stalky Tracker likes this.
post #10 of 16 Old 11-03-2018, 07:02 PM
Brockie's Avatar
It is one of the 10 or so Warning stickers attached to my bike. This one warning of using the hollow space within the forks tunnel for storing things like your wet weather gear or lunch box. LMAO. And of course in three languages!
Brockie is offline
High mileage DL1000s (is 60k+ a lot?) pooneej DL1000 from 2002-2012 10 02-19-2018 06:52 PM
SV Racing Parts, Nerve Bikewear High Visibility Riding Vest SV Racing Parts SV Racing Parts 6 02-18-2014 09:41 PM
Thinking through a high mileage bike eternal512 V-Curious 3 09-06-2013 12:52 PM
The DEFINITIVE DL1000 Mileage Calculator MightyShep DL1000 from 2002-2012 60 07-21-2009 02:31 PM
Gas mileage on my Vstrom OldIronsides DL1000 from 2002-2012 19 03-02-2008 04:00 PM
