California DL650 XT 600 mile maintenace - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By Hatchi
  • 2 Post By notacop
post #1 of 8 Old 10-17-2018, 07:39 PM Thread Starter
Hello, I have a 2018 V-Strom 650 XT coming up for it's 600 mile initial maintenance. The dealer quotes 300.00 because of the Throttle Body Synchronization part of the service. California is the only state requiring it. And I live in that state. Is it really necessary? I did buy the Shop manual and was surprised at the test equipment necessary to perform that task as well as disassembling the bike and running it without the tank in place. More than I think I'm comfortable with doing on my own. What are your thoughts?
kurtwd is offline
post #2 of 8 Old 10-17-2018, 07:59 PM
trapperdog's Avatar
California requiring a TBS? That’s a new one on me
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is offline
post #3 of 8 Old 10-18-2018, 02:06 AM Thread Starter
Yes California is the only state it says to inspect the TBS at the 600 mile maintenance service. For everyone else it doesn’t come up until you hit 7500 miles.
kurtwd is offline
post #4 of 8 Old 10-18-2018, 09:21 AM
I would not let the dealer do any service let alone an unnecessary tbs. Save your time and money. Change oil, check brake and coolant fluid levels, tire pressures, light function, inspect and lube throttle and clutch cable ends, torque battery terminals, Loctite and torque chain guard bolts, 2 front fairing mounting bolts, rear frame bolts in front of foot pegs, and engine ground wire under the front sprocket cover. Inspect all fasteners for looseness.
notacop likes this.
Hatchi is offline
post #5 of 8 Old 10-18-2018, 09:33 AM
Unless you notice a problem with the way the bike runs leave well enough alone. My 04 Wee has never had anyone mess with the sensitive parts and it still runs fine at 99K+ miles.
Dealers with personnel not well experienced can cause some grave issues that cost a lot to fix.
iamsmiling and Motor7 like this.
post #6 of 8 Old 10-18-2018, 11:45 AM
stuball's Avatar
Agreed, leave it alone if it's running fine. California owner, recently did the 600 mile service myself. No need to pay $400 for and Oil change, Chain Lube, and visual inspection.
SB
Stu Brown
stuball is offline
post #7 of 8 Old 10-24-2018, 11:11 AM Thread Starter
Thanks Guys for the well heeded advice. I will perform my own 600 mile maintenance sans the TBS part and call it a day.
kurtwd is offline
post #8 of 8 Old 10-24-2018, 01:09 PM
chicago's Avatar
I purchased 2 new stroms in CA. an '09 and then I traded for a new '13. for the 600 mile service of both I changed oil & filter and went over all the bolts to check for loose ones. as I understand the tbs for 600 mile service on CA bikes is more of an air quality requirement thing by a government agency maybe by CARB? I think most of ignore it.
14 tooth for me
chicago is offline
K6 DL650 20K Mile Maintenance FiSKars22 DL650 and DL650A - 2004 to 2011 5 06-03-2018 03:43 PM
2018 Summer Riding Farkles and Great Upgrades for the DL650 and DL1000 SV Racing Parts SV Racing Parts 1 06-01-2018 11:57 AM
Spring is Here!! AwesomeFarkles & Great Upgrades for DL650 and DL1000 Vstrom Models SV Racing Parts SV Racing Parts 1 04-13-2018 08:57 AM
DL650 fork swap with a Multistrada?? visovm Suspension and Tire Tech 14 12-08-2015 03:25 PM
