Coolant leak from small hose at water pump - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 10-02-2018, 10:52 PM Thread Starter
Letsgo2up's Avatar
I discovered a nickle sized water puddle under the bike that was coolant. The wet area in the skid plate indicates the coolant came from a small hose on the right side of the engine forward of the water pump. A quick search indicates this hose might drain a cavity that the pump would leak water to if the seal was leaking. It also indicates that an occasional small leak is normal or okay. I'm just looking for confirmation that this is normal, or that I have a problem. '06 Vee with 33K miles.
Thanks.
'06 DL 1000
'06 Bonneville T100
'01 Honda VTR1000
'09 Kawasaki KLX250
'07 Kawasaki KLR650
Letsgo2up is offline
post #2 of 5 Old 10-02-2018, 11:51 PM
blaustrom's Avatar
All your statements are correct. Typically the leak stops when all warms up a bit. To be sure keep an eye on the coolant level in the expansion bottle.
My WEE did it very intermittently but I never needed to add coolant during the season.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #3 of 5 Old 10-02-2018, 11:52 PM
larolco's Avatar
Totally normal.
It can happen now and then. If it continues to happen to the extent that you need to top up the coolant, you have a problem.
Otherwise, don't worry about it.
DRZ400SK17
larolco is offline
post #4 of 5 Old 10-02-2018, 11:55 PM Thread Starter
Letsgo2up's Avatar
Thanks gents.
'06 DL 1000
'06 Bonneville T100
'01 Honda VTR1000
'09 Kawasaki KLX250
'07 Kawasaki KLR650
post #5 of 5 Old 10-03-2018, 12:02 AM
BC Rider's Avatar
A small amount on cool down can happen. May go away completely in 100/200 km. Monitor coolant level and check to ensure it isn't leaking a large amount while you ride. The ones I've worked on had a ceramic disc on the back of the impeller rotating against a fixed spring loaded carbon ring. Grit can get between them and cause a dribble.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
Coolant leak out of the water pump My Strom DL1000 from 2002-2012 48 06-19-2016 04:29 PM
Coolant Leak from water pump vinpub DL1000 from 2002-2012 8 06-29-2010 10:08 AM
Small hose from water pump dustbuster DL1000 from 2002-2012 10 06-23-2010 08:08 PM
Used bottled water to top off coolant...hellp roborider DL1000 from 2002-2012 5 08-28-2008 01:22 PM
