Oil Drain Bolt Not Threading Nicely... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
  • 3 Post By blaustrom
  • 2 Post By thewarriorhunter
  • 1 Post By SECoda
  • 1 Post By spike55_bmw
post #1 of 7 Old 10-01-2018, 09:20 PM Thread Starter
Changing the oil tonight on my 05 DL650. I have an engine guard on it but left it on since there is a hole to insert a socket and get the oil drain bolt out. The bolt came out very smoothly with no issues. Now I'm trying to put the bolt back in and it will not thread nicely at all. I feel it get stuck and I have to apply more pressure than I'm comfortable with which makes me fear I'm setting myself up for a stripped or cross thread situation.
Should I feel it 'grab' when it first catches or should it be smooth all the way up to the crush washer? The washer is on the bolt so I know the bolt is not grabbing that. I'll remove the guard if I have to so I can get in there better but I was hoping to avoid that step.
thewarriorhunter is offline
post #2 of 7 Old 10-01-2018, 09:36 PM
blaustrom's Avatar
Thread the bolt with your fingers!!! There should be no need for any degree of force. The hole in you skidplate is probably not properly aligned with the bolthole, so take it off or at least drop down the back site to get better access.
richlandrick, VSrider and Gert like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #3 of 7 Old 10-01-2018, 09:39 PM
scab's Avatar
Just using a deep socket with your fingers will give you a little leverage but not enough to damage threads. Start by rotating backwards, like loosening, till you feel the threads fall-in the correct starting point. If you need more leverage than a deep socket and fingers, you're cross-threading.
If you're not living on the edge, you're taking up too much space.
scab is offline
post #4 of 7 Old 10-01-2018, 09:54 PM Thread Starter
Thanks, that was the confirmation I needed! First time doing this and I didn't realize how easy the skid plate could be dropped. Filling her up with some clean oil right now!
post #5 of 7 Old 10-01-2018, 09:55 PM Thread Starter
That's why I posted. I was attempting what you suggested but every time it was grabbing. I think the socket plus engine guard gave me the wrong angle.
Gert and scab like this.
post #6 of 7 Old 10-01-2018, 10:09 PM
SECoda's Avatar
Finger ratchets
My wife just doesn't understand why I need all of these tools. lol
You might need a small extension.
https://www.homedepot.com/p/GearWren...FYK_wAodQ8AJRQ
vegashotwheeler likes this.
SECoda is offline
post #7 of 7 Old 10-02-2018, 07:17 AM
spike55_bmw's Avatar
Those "wobble" type extensions for you socket wrench are helpful when you have those small misalignments. Cheap addition to your tool box from Harbor Freight. I also have the "ball" ended Allen wrenches for the same reason when working around brake calipers on various bikes.
spike55_bmw is offline
Engine Through Bolt seasdes DL650A - 2012-2016 10 04-26-2018 08:19 AM
Banjo bolt working its way loose Qflez Maintenance, Tech and Products. 2 01-27-2018 10:54 PM
Looking for tutorial on removing a stripped hex-head bolt bajakirch Maintenance, Tech and Products. 16 04-22-2017 07:18 PM
Bolt fell out, Help identify it GT_Hawk Maintenance, Tech and Products. 13 04-29-2015 11:14 AM
