blown fuse - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 07-02-2009, 09:07 PM Thread Starter
Martin's Avatar
blown fuse
So, the instrument cluster/signal lamp fuse of my K5 650 blew today.
I had been out riding in the rain on the highway for about 15 minutes before pulling off to check out a dirt road for possible future exploration...
As I was going down a rocky downhill I noticed the gauges were all blank and the neutral indicator was not lighting up... wtf?
I pulled the seat and had a look... no signs of mice or anything weird going on under there... just the blown 15A fuse. I replaced it with the spare and it was fine all the way home (but the rain had stopped).
It's a little unnerving because I've got a long trip planned for August and I've never had any problems like this.
I have the bike set up with fairly typical electrical farkles... Suz heated grips, Stebel horn, Powerlet outlet, Gerbings heated gloves but only the heated grips were in use at the time. Are they on the same circuit as the gauges/signal lights?
Any ideas?
Thanks in advance,
Martin
2019 650X
Martin is offline
post #2 of 7 Old 07-02-2009, 09:56 PM
silverstrom's Avatar
If it hasn't happened again I wouldn't worry too much about it. Just to be sure, set the bike up the way it was when the fuse blew and give the bike a good soak with a hose. If it happens again you'll know for sure, if not, no worries. Might be wise to pack some spare fuses just for peace of mind.
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
silverstrom is offline
post #3 of 7 Old 07-02-2009, 09:56 PM
OEM heated grips are run off the signals fuse.
post #4 of 7 Old 07-02-2009, 10:57 PM Thread Starter
Martin's Avatar
OK, thanks GW... I'll have a look at the grips/controller/wiring.
- Martin
2019 650X
Martin is offline
post #5 of 7 Old 07-03-2009, 11:17 AM
I had the same problem last year. On my bike it was a short in the rear signal wires. The wire sheathing had worn through where the wires run past the frame going to the back of the bike. Might be worth a look.
2005 DL650
JBreedon is offline
post #6 of 7 Old 07-29-2017, 06:07 PM Thread Starter
Martin's Avatar
An update... 8 years later... the same fuse blew. The bike is a 2005 Wee with over 80,000 km on it.
I'm not too worried at this point... I've got no trips planned and the bike does still run and the headlights work without that fuse. When I pull the cowling to replace my fork seals next month I'll have a look for chafed wires.
I know some people have found a mis-routed harness on early Wees but I think I checked for that the last time. Any other known trouble spots?
- Martin
2019 650X
Martin is offline
post #7 of 7 Old 07-29-2017, 06:16 PM
No help from me on the fuse but have you tried a Seal Mate on your fork seals?
wingstrom is offline
