Shift lever rubber pad on V-strom - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 07-02-2009, 03:57 PM Thread Starter
cyclerama2000's Avatar
How do I remove the old one and install the new one?
I can cut the old one off, but there's nothing removable to install the new one.
TIA
2004 DL650 - Blue
Yes, a DL650 can definitely do a major smokey burnout!!
cyclerama2000 is offline
post #2 of 5 Old 07-02-2009, 04:17 PM
This is one case where, "If it don't fit, use some Vaseline and a bigger hammer" nearly applies. Vaseline is a petroleum product and bad for rubber. Use some silicone or a strong solution of dish soap and water to lubricate the rubber and force it over the end knob.
post #3 of 5 Old 07-02-2009, 04:33 PM Thread Starter
I'll try for the soap deal. It just seems odd that the new piece has the hole in one end larger than the other end and both are too small for the rod, especially with that non-removable end knob.
Hmmm - the hole is too small and the rod is too large. Makes it sound like a different situation, but that one always works out so hopfully this one will too. :~)
2004 DL650 - Blue
post #4 of 5 Old 07-02-2009, 05:10 PM
nec
What is the part number for it (the rubber part)?
Thanks!
nec is offline
post #5 of 5 Old 07-02-2009, 05:17 PM
Thanks!
25652-20C00 for all models.
