Automated chain lubing - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By Bogfarth
  • 1 Post By Brockie
post #1 of 10 Old 09-13-2018, 08:33 PM Thread Starter
Is anyone out there using one of those devices, attached near/above the drive chain, which lubes the chain by releasing drops off oil onto the chain, not sure what releases it ? Scottoiler is one brand, there are others...
Would like to hear if this works well & is worth the investment.
Thank you !
Juergen
Portland, OR
1979-1993 Yamaha XT500, (Germany& US)
1993-2016 BMW R100GS, (US)
2016-20.. DL1000ADV
juergens53 is offline
post #2 of 10 Old 09-13-2018, 11:26 PM
V2man's Avatar
We use to run one of these on our 2012 Wee's and they were really good, not much fling and the oil reserve last for ages.
https://www.pro-oiler.net/
But when we moved them onto our 2014 Vee's we could not get them to work properly. It appears they were getting EMI which was mucking up the system and it didn't matter what we tried they just didn't work the same.
So we have removed them and fitted these, haven't been on long but so far there is little fling, easy to adjust and look like they go awhile between fills.
https://www.tutorochainoiler.com/
Cheers V2man & GotaV2
2014 DL1000A 2014 -
2012 DL650L2 2013 - 2014
2007 DL1000 "Bowser" 2009 - 2013
V2man is offline
post #3 of 10 Old 09-13-2018, 11:30 PM
Bogfarth's Avatar
Scottoiler, Tutoro, chameleon, pro oiler, Loobman, and others I do not recall at the moment.
I use a Tutoro. No vacuum lines, no wires, just mount and run the tubing. Does a lovely job of keeping the chain shiny, too.
Big B likes this.
Being slow doesn't make a boring bike. I had a R1 which I thought was boring. Boring is a bike that doesn't speak to you. If you like what your bike is saying let it's voice take you to far flung places. - Vertical C
Bogfarth is offline
post #4 of 10 Old 09-14-2018, 01:14 AM
I use a ScottOiler E-System and it works fine without leaving drips on the garage floor .
Pretty much fill & forget , great on long journeys , just top up every 1000 kms or so .
If I was to get another bike I'd probably use the new ScottOiler X-System which is even easier to set up and cheaper .
DL650A L3
KLR650
CB900 Bol d'Or
Yamaha Nifty Fifty ( great way of saving for university )
RD350LC
CB125twin
Farm Bike Suzuki Van Van 125
reasonable is offline
post #5 of 10 Old 09-14-2018, 02:04 AM
Tutoro......system just simply works, will never own another chain drive bike without one.
post #6 of 10 Old 09-14-2018, 02:11 AM
Brockie's Avatar
Oiling/Cleaning Thread
There is a thread here https://www.stromtrooper.com/v-strom...er-review.html where members have discussed different auto oilers and how to extend the life of your chain.
Big B likes this.
Brockie is offline
post #7 of 10 Old 09-14-2018, 02:28 AM
https://www.ebay.com.au/itm/Motorcyc...IAAOSw-mdbj43g
Surprisingly good. There's one mod to them which improves this a LOT, and that's to put a small fuel filter in the output line somewhere to act as a reservoir and spread the drips out. Plumbed one onto my wife's bike and set it up to drip on the chain just before the front sprocket. She loves the lack of maintenance, just gives it a pump monday morning and otherwise fergetaboutit.
Yes, you can spend a lot more but this is simple, inexpensive and reliable and also no mess once you learn not to overdo it.
PeteW is online now
post #8 of 10 Old 09-14-2018, 04:38 AM
Osco is another name you may want to check out. It's not an auto-oiler in the sense that you can forget about it altogether, but it's probably the simplest to install.
You mount a reservoir somewhere to the frame, in a way that it's accessible when on the bike. This reservoir has a plunger that you pull, and a spring then pulls the plunger back into the reservoir. This feeds a measured amount of oil into the oil line. This line is zip-tied along the frame and the swingarm to a convenient location somewhere above the chain. It drips the oil on the chain over a period of about 15 seconds. So during this period you have to be moving relatively slowly, or the oil will immediately fling off. Other than mounting the reservoir and the oil line, there's nothing you need to do to set it up.
Other systems are automatic in the sense that they release a drip every x seconds. But these then require some vacuum or electric connection to detect that the bike is running in the first place, and to adjust the flow to the chain speed. This means more wiring.
BackPacker is offline
post #9 of 10 Old 09-14-2018, 08:07 AM
Another vote for Tuturo.
I've had mine for 6 months. Once adjusted properly, it's pretty much maintenance free. Been happy with it.
2008 Suzuki Vstrom DL650
2013 Yamaha WR250R
2004 BMW R1150RT
2002 Ducati 998 Superbike
2001 BMW R1200C Phoenix/Independent
1982 BMW R100RT
2003 Kawasaki Ninja 250r - Sold
1985 Yamaha FZ-750 - Sold
1984 Kawasaki GPZ-750 - Sold
bmwguy is offline
post #10 of 10 Old 10-07-2018, 08:33 AM
I use the Cobrra and after getting the hose routed properly it seems to do exactly what they advertise. View their comparison: https://bestdamnchainoiler.com/
mushu is offline
Chain and Sprocket Combinations, with EK Chain Breaker - Press Fit Rivet Tool SV Racing Parts SV Racing Parts 188 09-24-2017 02:34 PM
Chain and Sprocket Combinations with RK Chain and Press Fit Rivet Tool SV Racing Parts SV Racing Parts 104 07-14-2017 11:12 AM
Chain Slack Rebel Trepidator Maintenance, Tech and Products. 37 03-06-2015 05:24 AM
Chain Installation On 2012 Glee Strom Tompkr DL650A - 2012-2016 0 04-01-2014 03:11 PM
