2007 DL1000-easy Coolant Add? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 09-10-2018, 08:01 PM Thread Starter
Has anyone figured out a way to add coolant to the reserve bottle/tank that sits under the driver's right side front fairing? Seems like some type of flexible funnel might work. I just want to add some to the bottle without taking off the fairing, if possible.
TIA!
87Duckfan is offline
post #2 of 6 Old 09-10-2018, 08:09 PM
Small turkey baster worked for me. Careful - they sometimes drip a little.
Retired USAF MSgt (E-7)
Retired Rider - 2016 (3 V-Strom 1Ks, Concours, Burgman 650, 2 Honda 750 Nighthawks, and more over 40 years)
My website: www.RidingWV.com
VStrommer263 is offline
post #3 of 6 Old 09-11-2018, 07:41 AM
Use a funnel made to add automatic transmission fluid to a car. These have a very long neck on them. You can put a piece of heater hose or similar sized tubing on the end. You can stick that down into the reservoir or radiator to fill them up from the handlebar area.
realshelby is online now
post #4 of 6 Old 09-11-2018, 07:16 PM
bwringer's Avatar
Two long skinny funnels.
It's what I happened to have, and it works fine.
Also, make sure you don't overfill the reservoir. It'll puke the extra out next time you're idling in stop and go traffic, and that's just tacky. DAMHIK.
Just up to the line about 1/3 of the way up is plenty.
bwringer is online now
post #5 of 6 Old 09-11-2018, 10:23 PM
Karlos's Avatar
I carry one of the really small Gatorade bottles of coolant onboard. Easy to sneak it up from the bottom front and pour a little in. Make sure you write DO NOT DRINK on it.
2004 DL1000
2004 KTM 525EXC plated
Karlos is offline
post #6 of 6 Old 09-13-2018, 05:52 AM
Half a meter of garden hose with a regular funnel stuffed into one end.
BackPacker is offline
2007 DL1000 Wiring diagram Chewbaca Maintenance, Tech and Products. 1 03-25-2017 02:26 PM
2007 DL1000 Front brake rotor question Russ DL1000 from 2002-2012 8 05-11-2015 12:49 PM
2007 dl1000 tbs sync issue Curtf DL1000 from 2002-2012 8 07-15-2014 04:18 PM
