Front Brake Lever Lubrication? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 07-02-2009, 10:51 AM Thread Starter
iamsmiling's Avatar
The front brakes on my Wee appears to need some lubrication. So, do I simply lubricate the lever pivot or is there something in the master cylinder linkage that needs lubing too?
Once I get the lever compressed more than 50% of travel, it seems to get a bit "catchy" . . .
iamsmiling is offline
post #2 of 4 Old 07-02-2009, 11:02 AM
Just the pivot at the lever. There are slide pins on the calipers that get high temp brake grease but they will cause uneven brake pad wear if dry, not what you are feeling.
post #3 of 4 Old 07-02-2009, 12:50 PM Thread Starter
iamsmiling's Avatar
Excellent, a five minute process . . . once I locate the lube.
post #4 of 4 Old 02-28-2015, 07:34 PM
kiwi_outdoors's Avatar
lube on front cliper pns
Okay - I took my calipers apart to lube them with silicone brake grease - and to my amazement I discovered that on one of the pins in each pair - the rubber gasket thingy is really a bushing as it passes all they way through the receiving hole that the pin goes in to. And its shown this way in the manual. What a surprise. So you betcha you need grease - a dry pin will not slide over rubber.
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
