Clunking noise at take off and low revs - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 19Likes
post #1 of 34 Old 08-24-2018, 09:30 PM Thread Starter
gopi.sandy's Avatar
Hi folks,
I started noticing a clunking noise when going from stop and when accelerating from low revs. It's a 05 dl1000 with 64k.
I checked to see if anything was loose but alls good. The noise seems towards front and probably the left side. I've heard stories of loose magnets of the rotor/stator but I don't have any charging issues.
Any and all help is appreciated!
Sent from my SM-G960U using Tapatalk
gopi.sandy is online now
post #2 of 34 Old 08-25-2018, 03:15 AM
Gert's Avatar
Have you checked both your front brake calipers for release? I suggest that you lift the front end off the ground, spin the front wheel and see if any noise can be heard. Remember to apply the front brakes prior to spinning the wheel. You may hear the scrap of brake pads against the rotors. If one of the caliper are not releasing, you should be able to hear the knock as it releases. Normally lube required on the sliding pins. Oh and if you ask how to lift the front wheel off the ground... make use of the search function, there are many threads on the subject.
If you think the sound is from the left engine cover, then by all means check the magnets. Normally your ear against a plank or screw driver that is against the cover will let you localize the sound. For the magnets take voltage readings at different rpms. Let us know if you find anything amiss.
Gert is offline
post #3 of 34 Old 08-25-2018, 03:22 AM
Gert's Avatar
Something else to check is the steering head bearings for any play. Could even be a faulty shock. Basically a process of elimination.
Gert is offline
post #4 of 34 Old 08-25-2018, 07:09 AM Thread Starter
gopi.sandy's Avatar
Hi gert,
Thanks. I checked the front wheel calipers as you mentioned and I see that the left caliper doesn't completely release and drags a bit. I don't hear any noise when I release the brake but rather when I apply it.
I checked the brake disc and it looks like the left one has some sliding movement in it. As in when you apply the brakes the caliper gets hold of the floating disc but the disc moves a bit. The mounting is secure it's just the floating part.
I am gonna clean the calipers and get new pads. So i chuck the caliper?
Appreciate the help!
post #5 of 34 Old 08-25-2018, 08:36 AM
Brockie's Avatar
How old are the chain and sprockets?
Jeepster09 likes this.
Brockie is offline
post #6 of 34 Old 08-25-2018, 09:43 AM
Gert's Avatar
The calipers are designed to slide a bit, as they takes up the slack in the braking process, hence the use of sliding pins. No need to replace the calipers if they are still serviceable. Simply refurbish both as a set for equal braking ability. Check that the pads are in good condition. The caliper bolts have a tendency of coming lose / falling out, so ensure they are correctly torqued.
Brockie's suggestion of checking the condition of the chain and sprockets, should also be done. Look for hooked / worn sprocket teeth, especially on the front sprocket.
Gert is offline
post #7 of 34 Old 08-25-2018, 10:18 AM
John David's Avatar
I changed the chain and sprockets on my DL650 and the clunk went away.
Kerri Miller and Jeepster09 like this.
John David
1973 Honda CL173 Being over hauled
1975 Honda CJ360 T Under construction
2005 Suzuki V-Strom DL-650
"Strive not to be a success, but rather to be of value." Albert Einstein
John David is offline
post #8 of 34 Old 08-25-2018, 10:50 AM
Cush drive rubbers were the source of my clunk on start-up.
Big B and iamsmiling like this.
Bentwee is offline
post #9 of 34 Old 08-25-2018, 11:20 AM
OCADVR's Avatar
Same here.
Jack
SoCal 92691
"I feel more like I do now than I did a while ago."
OCADVR is offline
post #10 of 34 Old 08-25-2018, 11:36 AM
Very likely worn cush rubbers in the sprocket carrier, if original bearings I would also get them replaced as well.
gopi.sandy likes this.
