Jump starting - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 27 Old 07-19-2018, 02:20 PM Thread Starter
Jump starting
Portable tire pumps like the Slime 40001 Motorcycle Tire Inflator come with multiple connection options, one being a cord with a pig-tail and alligator clips to connect to the battery.
Question: If you had two motorcycles and one's battery was dead, could you use this pig-tail connector to jump start the bike?
andrewmlangford is offline
post #2 of 27 Old 07-19-2018, 03:04 PM
erci's Avatar
Not ideal, because typically you want the vehicle getting a jump to only get the positive lead and the negative should go to ground. BUT.. loads of people do it wrong and connect + to + and - to -... after some sparks, the jump does work. So.. while I wouldn't use that approach, I am guessing that yes, it can be done.
Has anyone tried?
erci is offline
post #3 of 27 Old 07-19-2018, 03:47 PM
Can you jump start with only 15 amps or so? These SAE battery connectors are not very heavy. kfh000
erci likes this.
kfh000 is offline
post #4 of 27 Old 07-20-2018, 10:11 AM
I would say no. The wires are too small. Just look at the wire from the battery to the starter solenoid and that is only running 1 foot.
Mikeys is offline
post #5 of 27 Old 07-20-2018, 10:19 AM
OydnaR's Avatar
I wouldn't jump with less than 6ga wire, 4 ga preferable, there's a lot of amps, even a 6ga wire will get hot if it has to crank more than 2 seconds
IBA#9560
Copyright (c) 2019
OydnaR is offline
post #6 of 27 Old 07-20-2018, 10:21 AM
Lrobby99's Avatar
No longer can one wire the positives together, then touch bumpers to achieve circuit.
K9 Wee likes this.
2018 1000XT, black. The Night's Watch. Givi engine bars, rear wheel mud guard, radiator screen. Givi V56 Litre Monokey topcase. Puig screen. Freeway Blaster horn. Speedohealer. SW Motech guards for R. brake reservoir, R. brake cylinder, exhaust pipe valve. Aprilia Tuono mirrors.
Lrobby99 is offline
post #7 of 27 Old 07-20-2018, 11:06 AM Thread Starter
Thanks for everyone's input!
post #8 of 27 Old 07-20-2018, 04:27 PM
Bumpers made of plastic now. I was kind of hoping a motorcycle starter would not take quite the amps that even small cars take.
Kfh000
kfh000 is offline
post #9 of 27 Old 07-20-2018, 04:40 PM
chicago's Avatar
yeah likely melt the small gauge wires.
14 tooth for me
chicago is offline
post #10 of 27 Old 07-20-2018, 04:48 PM
RCinNC's Avatar
Aren't starters on bikes drawing anywhere from 50-100 amps when they're turning the engine over? That's a lot of amperage running through an 18 or 22 gauge wire that's several feet long (which is what a lot of those wires are in things like a small air compressor). I checked my amp rating chart, and a 12 volt, 50 amp load on a wire that's 7 feet long requires 12 gauge wire. Seven feet of wire at 100 amps and 12 volts would require 10 gauge.
erci likes this.
RCinNC is offline
Tags
jump start , slime pump
