sick strom - stalling - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 20 Old 06-29-2009, 07:51 AM Thread Starter
My 2006 v-strom started acting up this week. Coming home from a ride it would stall as soon as I'd let off the throttle. I managed to limp home by re-starting and then keeping the rpm's up around 4000 or more. Not a fun ride.
Took the bike apart and cleaned the air cleaner and changed the spark plugs (badly carboned up). Took the bike for a spin and it ran great. Rode home (highway mostly) and it ran no problem.
The next day I put it up on the centre stand, started it and put in gear to spray the chain. As soon as I put it in gear, it stalled. Re-started and it would idle ok. Reved it up and it would rev but as soon as I'd let go the throttle, the rpm's 'crash' and it stall (ie same prob as before).
It's now in the shop but I was doing some internet searching for similar problems and I've found nothing.
I'm a little panicky as I'm supposed to start a long ride next Sunday.
Sue
Silver/Blue DL650K6
sdorleans is offline
post #2 of 20 Old 06-29-2009, 10:51 AM
I've never heard of that one. Try asking at http://www.vstrom.info/Smf/index.php too as that's a more technically oriented site. I'm thinking throttle position sensor or gear position sensor. http://www.vstrom.info/Movies/TPS_TB_Tuning.mpg includes the process. TPS checking is covered in http://vstrom.info/Smf/index.php/topic,7061.0.html
post #3 of 20 Old 06-29-2009, 10:59 AM
V-Tom's Avatar
I doubt it's the issue but what was the idle set at?
Did the problems surface shortly after gassing the bike?
..Tom
SMIDSY detailed report.
V-Tom is online now
post #4 of 20 Old 06-29-2009, 11:43 AM Thread Starter
It's regular idle is set at about 1100rpm or so. When it first happened I couldn't keep it idling and by the time we limped it home, I could start it and it would idle (would still die if rev'd up and let go). After changing the plugs and cleaning the air filter, it ran great for a run around the block and then the ride home (mostly highway). Next day it would start and idle, but wouldn't keep running if I rev'd it up and let it go.
It was about half way through a tank of gas and I'd been out for a few short rides over a couple of days, on the tank.
Sue
Silver/Blue DL650K6
post #5 of 20 Old 06-29-2009, 11:54 AM
The 650 idle is to be set between 1200-1400rpm. 1100 is too low. Also, do not lube the chain with the engine running and in gear. Many bad things have happened and more lube gets flung off than penetrates.
post #6 of 20 Old 06-29-2009, 12:40 PM
Banned
Question
Q1:How many miles does the bike have on it ?
Q2:What maintenance has been performed on the bike & at what mileages ?
Q3:I know you said you just cleaned the air filter, but how many miles does the air filter have on it ? What color is the air filter ?
P.S. You do realize that the service manual calls for a new air filter every 11,000mi. on a DL650K6 ? The only exception might be a washable air filter such as a K&N.
XLonDL650 is offline
post #7 of 20 Old 06-29-2009, 01:23 PM Thread Starter
The bike has 58000km and it was overdue for service. Last major service was over a year ago at 36000km when it got the new K&N filter, plugs, checked for bucket and shim stuff, throttle body, etc. Oil changes and chain maintenance are done regularly. Just got a new front tire, brakes, brake fluid. Up until this past service, everything was done pretty close to the book.
The filter is a K&N and it was recharged. It was dirty, but not that bad.
The idle has always been just over the 1000, so maybe almost 1200, but certainly never as high as 1400. I've had the bike 3 yrs as of Friday.
Silver/Blue DL650K6
post #8 of 20 Old 06-29-2009, 01:32 PM
Really, set the idle at 1300 and see how it works first.
post #9 of 20 Old 06-29-2009, 01:35 PM Thread Starter
I've posted in the other forum as well.
There have been NO errors showing on my bike. I did not get the FI error.
Still no news from the dealer.
Sue
Silver/Blue DL650K6
post #10 of 20 Old 06-29-2009, 01:38 PM Thread Starter
I understand... but this is NOT the problem. It will idle. Rev'ing it and letting go the needle 'crashes' to zero and the red light goes on and the bike is dead all in a split second.
Pulling in the clutch and rolling off the throttle is enough to kill the bike.... immediately.
I couldn't even ride it to the shop and had to get a tow. It's there now, but no solutions yet.
Sue
Silver/Blue DL650K6
