No power, blowing 30A fuse repeatedly - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 14 Old 07-03-2018, 08:23 PM Thread Starter
omgyouresexy's Avatar
So my bike broke down after the first hour of a road trip to NC. Luckily I found a place to store it until later, but I want to be proactive getting some repair advice. I'm going to tackle it when I get home.
Summary:
- 2007 dl1000
- Lost all electrical power after shutting off at rest stop. No lights, no nothing.
- Rolled bike to auto shop next door, they help me diagnose
- Battery checked out with good voltage
- Pulled the small fuses, all we're good
- Large 30A fuse was blown. Replaced with spare, it immediately blew when I reconnected the battery.
- Wrapped the exposed terminals near the 30A fuse in case they had shorted on the frame, hooked up the battery first, blew another fuse after turning on the kill switch
Electrical work is like heiroglyphics to me. I am completely unfamiliar with what the components are called. However, I guess now's the time to learn.
- What would be the most likely candidate? Or easy thing to check first?
- Shop guy said the 30A fuse blowing but not the smaller ones point to something like the stator or something larger. Sound right?
- Can anyone point me to a useful thread or YouTube video that walks me through troubleshooting or how to look for shorts? Or maybe a reference to what certain voltages should be across certain elements?
- Is this a "take it to the shop" problem?
I think people have referenced a stator recall? I don't know if I've had it done or even if it includes my year.
Thanks all.
Sent from my SM-G935V using Tapatalk
Johnson City, TN... originally from NC
Rides:
2008 V-Strom 1000
2006 Kawasaki Nomad 1600 (w/ sidecar for the boy)
omgyouresexy is offline
post #2 of 14 Old 07-03-2018, 08:40 PM
locoblanco's Avatar
First thing is to get a schematic and look at the circuit that is protected by that 30a fuse. Something is shorted to ground, and by following the schematic you will find all the connections, etc., that are associated with that circuit.
Gert likes this.
locoblanco is offline
post #3 of 14 Old 07-03-2018, 09:39 PM
There have been posts of abraded and or burnt wires that get shorted. May have to remove the tank and plastic to get at the wiring harness.
post #4 of 14 Old 07-03-2018, 10:03 PM
Stalky Tracker's Avatar
What Loco said. Really need a DL1000 schematic or access to one to be sure.
The DL650 K4 schematic I have shows the Wee's 30A fuse with the starter, starter relay, and associated interlocks, BUT the DL1000 might be different.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #5 of 14 Old 07-03-2018, 10:15 PM
dmfdmf's Avatar
It could be (and probably is) an abraded wiring harness as @notacop suggested. However, a shorted regulator/rectifier (R/R) could explain the symptoms too and easier to rule out. Step one is to unplug the connector to the R/R to take it and the stator out of the circuit. If that fixes the fuse blowing then its probably a shorted R/R, I've never heard of shorted stator wires causing the main fuse to blow but I could be wrong so measure the stator for resistance and shorts to be sure to rule that out. If it still blows the fuse with the R/R disconnected then start looking for harness abrasions (which, unfortunately can be difficult to find). I'm not sure where the R/R is on a DL1000 and I think it moved around a bit on the early models so maybe someone else can advise.
Next Up: ?
dmfdmf is offline
post #6 of 14 Old 07-03-2018, 11:03 PM Thread Starter
Thanks, all. I'll start to check it out when I'm back. I appreciate all the support. I'll try to come back to this thread with questions as I learn things.
So far I'll try to check first for:
- short in the R/R
- short in the ignition
Rides:
2008 V-Strom 1000
post #7 of 14 Old 07-04-2018, 06:54 AM
Gert's Avatar
greywolf post#2 from https://www.stromtrooper.com/dl650-d...main-fuel.html
"Try wiring a headlight bulb to the fuse terminals. When a short occurs, it will light the bulb instead of blowing the fuse. You can push the wiring around and see what area might be causing the problem. Hopefully, you can find a spot where pushing the harness around will cause the light to go on and of."
Gert is offline
post #8 of 14 Old 07-05-2018, 01:29 PM
bwringer's Avatar
- short in the R/R
First I would inspect carefully for abrasion and damage somewhere in the wiring harness. You'll need to raise or remove the tupperware and tank to get eyes on everything. Also check all the connectors for corrosion, damage, burning, etc.; there's a connector under the left fairing "cheek" that corrodes and fails on pretty much every V-Strom, but the usual symptom is sudden loss of headlights.
If there's any added wiring or anything non-stock, these are usually prime suspects, but it does happen that the stock harness gets installed wrong, or someone moves or damages something during servicing. The spaces available are very small.
This shouldn't require any "wizardry", just eyes and fingers!
bwringer is offline
post #9 of 14 Old 07-05-2018, 07:34 PM
remember your first problem was the bike dying so look for that cause first. Inspect the reg/rec and stator considering the first thing that happened was you lost power. That means the bike was not charging the system and caused the main issue or when the offending part when bad it caused the short which blew the 30A. Other than the fuse issue, my buddy just had the same thing with the bike dying out of nowhere. it was his stator. I have a feeling your issue is contained within one of these 2 parts.
jccity6 is offline
post #10 of 14 Old 07-05-2018, 07:56 PM Thread Starter
Keeping in mind that the issue happened when I turned on the ignition and hit the starter button, would that lead to the stator or the ignition or something else most likely being shorted?
Rides:
2008 V-Strom 1000
