Phone won’t charge from usb charger - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 06-26-2018, 04:40 PM Thread Starter
A couple of months ago I put in one of those Eastern Beaver PC8 boxes. I bought a compressor and that runs fine off the SAE plug from there. I also have a Trackside USB port, and while I thought I had verified it works to charge the phone, I discovered a day into this three week trip from San Francisco to Denver and back that it’s definitely not charging my iPhone *now*.
I’m in Denver for a few days so I have a little time to look at it. I’ve googled and haven’t seen anything helpful yet. Any ideas to what I might have going wrong? The fact that the compressor still runs fine is confusing me.
kgoess is offline
post #2 of 10 Old 06-26-2018, 04:52 PM
stuball's Avatar
Have you verified the Charger works, IE; plugging into Car ?? Sometimes those chargers can be faulty...
stuball is offline
post #3 of 10 Old 06-26-2018, 05:45 PM Thread Starter
I don’t have any SAE plugs around besides the ones on the bike which don’t work. I’ll definitely try buying a second one if I can find one here in Denver.
kgoess is offline
post #4 of 10 Old 06-26-2018, 05:48 PM
BC Rider's Avatar
Hot and ground reversed on back of unit? Ignition on if it is not on the always on circuit?
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #5 of 10 Old 06-26-2018, 05:58 PM
PerazziMx14's Avatar
Don't worry a buddy of mine has a Battery Tender SAE to USB plug fail about 2 hours into our week long trip. Fortunately just about every auto parts store or big box store has 12v USB ports or battery packs to get you going again.
PerazziMx14 is offline
post #6 of 10 Old 06-26-2018, 07:34 PM
PineLaneRider's Avatar
I've had 2 of these fail after forgetting to put the cover on and having a rain shower. I have taken to carrying a replacement in my top box, just in case. I think I paid $7.99 a piece for them so it isn't devastating, but its very inconvenient when it fails!
PineLaneRider is online now
post #7 of 10 Old 06-26-2018, 08:40 PM Thread Starter
Well the local auto parts stores didn’t have SAE to USB, so I bought an SAE to cigarette lighter and bought a cigarette lighter to USB. Still no dice. I plug in the phone and nothing happens. I’ll go to the hardware store tomorrow and buy some electrical testers, or see if I can figure out how to post photos on here.
kgoess is offline
post #8 of 10 Old 07-14-2018, 03:23 PM Thread Starter
After further investigation, it turns out I had the SAE plugs wired in backwards?? The SAE pigtails have a red wire and a grey wire, and I assumed the red wire would go into the hot side of my PC-8 box, but no! I fried a bunch of USB connectors before I figure it out.
Oh, I see, if I even bothered to read wikipedia
"The polarity of the connector, when installed in a vehicle and attached to a battery, is always such that no short circuit will occur if the exposed terminal were to touch the vehicle chassis. In most vehicles, this means that the exposed terminal connects to the negative terminal of the battery."
https://en.wikipedia.org/wiki/DC_con...#SAE_connector
kgoess is offline
post #9 of 10 Old 07-14-2018, 03:35 PM
it its mini usb make sure the actual connector works with your phone. I have a Samsung phone that is sensitive to the length of the mini usb connector. It wasn't charging when I plugged it in so I switched to a new usb and it was fine. You could verify if there is poser to the cord w/ a volt meter.
Current: '12 Dl650, '06 ST1300, '89 Transalp, '84 XL350R, '07 TRX350TM,
DownOnTheFarm is offline
post #10 of 10 Old 07-14-2018, 04:46 PM
Hank122's Avatar
I've been using the dedicated (hard wired) USB charger for a while now as well as the cigarette lighter style for my other needs (mini compressor, etc).
Adventure Tech sells the dedicated ones, they have both a 1 amp and 2.1 amp connectors.
Henry
"Rock bottom will teach you lessons that mountain tops never will..."
2016 V-Strom DL650 (red) 'Sweetness'
2011 V-Strom DL650 (white)
Hank122 is offline
