Reinstalling rubber mat on rear rack? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 06-26-2009, 11:00 PM Thread Starter
'09 DL650A, just got home with it. PO removed the rubber mat from the stock aluminum rack in back. I would like to put it back on, but I cannot get the rubber nipples back through the holes.
I tried:
- just pulling with pliers, then added a little oil as lubricant and tried again
- tucking it through bit by bit with a small flat blade screwdriver
- pushed and pounded from the top with the handle end of the screwdriver
I think increasing brute force will just tear the rubber.
Anyone got any suggestions?
barker is offline
post #2 of 6 Old 06-26-2009, 11:07 PM
Um, that's strange. I pulled the rubber mat off my '07 ABS Wee and had little trouble putting it back on. Try again using dish detergent as a lube, pushing from the top and pulling from the bottom at the same time.
Good luck.
George
George Johnson is offline
post #3 of 6 Old 06-26-2009, 11:09 PM
The rubber is remarkably resilient. Putting long nose pliers through the hole. grabbing the projection lubricated with silicone grease/spray and pulling with lots of force will usually do the trick. I'd avoid petroleum products on anything that may be real rubber.
post #4 of 6 Old 06-27-2009, 09:31 AM Thread Starter
Thanks guys, I got it! I used soapy water for lube, as George suggested. I tried greywolf's suggestion of putting the needlenose through the hole, but you actually get less grip that way. I then swapped to regular pliers, which give grip across the entire protrusion. Pull with vigor, regrip. Pull with vigor, regrip. Repeat until "pop"! Do in 4 more places, rinse remaining soapy water off rack, and done.
Thanks again.
barker is offline
post #5 of 6 Old 06-27-2009, 12:12 PM
Now I remember what I did. I tied a string around the rubber and pulled it through with the string wrapped around the nose of the pliers after grabbing it.
post #6 of 6 Old 06-27-2009, 12:27 PM
rcacs's Avatar
I actually cut off a small bit of the "corner" (does a round thing have corners?) of each nipple.
Cheers
rcacs is offline
