Fender bolt size? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By dravnx
  • 1 Post By brentyhaha
post #1 of 8 Old 06-19-2018, 12:21 PM Thread Starter
Fender bolt size?
Looking at the parts diagram for a 2017 and the front most fender bolt part number doesn't seem to follow a naming convention that I can decipher.
BOLT 45241-17K10
Does anyone know the actual dimensions of this bolt?
BillfromSkene is offline
post #2 of 8 Old 06-19-2018, 01:45 PM
dravnx's Avatar
The fender bolt is a shouldered bolt that doesn't put any pressure on the plastic fender. A non shouldered bolt will eventually crack the fender. Been there, done that.
notacop likes this.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
dravnx is offline
post #3 of 8 Old 06-19-2018, 03:35 PM
Dravnx may be right but some of us have replaced the shouldered bolt with a bolt of convenience when we had to hack the original bolt apart to get it out for various reasons.
I'm never sure why folks don't go to the dealer when replacing parts unless they find the originals are just too expensive.
At least calling a dealer and talking to the parts clerk may solve a lot of questions.
post #4 of 8 Old 06-19-2018, 06:36 PM
p38arover's Avatar
I don't know why people can't look at a bolt and determine its size and pitch, especially a metric bolt.
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is offline
post #5 of 8 Old 06-19-2018, 09:24 PM
P38, most hardware stores now have a bolt and nut display so you can take in your questionable item and try to match threads and size.
I think they have SAE and Metric displays.
I'm with you on your post. But maybe we've played with hardware all our lives and sizes aren't a mystery to us. Others are just learning.
post #6 of 8 Old 04-24-2019, 08:40 PM
brentyhaha's Avatar
Does anyone happen to know the length of each side? When looking at diagrams the right side bolt looks longer than the left. Long story, but as I was adding a light bar to the front fender, we drilled out the crappy stock bolts and then they got tossed during a clean up.
I know M6, I just need to know the length of each.
Thanks.
brentyhaha is offline
post #7 of 8 Old 04-24-2019, 10:56 PM
Brockie's Avatar
Thanks.
They are mushroom headed shoulder bolts. Identical both sides.
21mm overall
13mm thread length
4mm shoulder
4mm hex
DO NOT use a normal M6 threaded bolt. You must use a shoulder bolt.
Brockie is offline
post #8 of 8 Old 05-04-2019, 08:50 PM
brentyhaha's Avatar
Thanks a million. Found some at a local bolt store and they fit like a glove! Fender back on and light bar work greats.
Brockie likes this.
