Burnt wire. How? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 21 Old 06-01-2018, 10:02 PM Thread Starter
Burnt wire. How?
I noticed Tuesday night that I had no headlights on my Wee. Looked into it today and found the hot connection coming out of my fuse box towards the light relays was burned to a crisp AFTER the 20A fuse, which never blew. WTF? Isn`t that the whole reason for fusing circuits? What might I have wrong here? I don`t know much about electrical troubleshooting, but I see nothing wrong with the rest of the headlight system (EB relay kit, connections, plug-ins to lamps). I did move the 2A fuse to my voltage gauge away from the headlight fuse, don`t know why I had them right next to each other when there are plenty of empty spots, but still ...
I`m trying to upload a picture directly to the website, but not sure if it will show up- have only done it previously by tying in to PhotoBucket.
bdesj is offline
post #2 of 21 Old 06-01-2018, 10:10 PM Thread Starter
Hmmm, upload worked but too tiny to see. Here is a blow-up.
bdesj is offline
post #3 of 21 Old 06-01-2018, 10:32 PM
Clayyalc's Avatar
The PC-8 is rated for 20A bust not constant. What are your headlights drawing?
The screw down terminal block can create a high resistance spot if the wire has a bad connection. The resistance while create heat and burn up. Most screw down blocks of that size are only rated for 15A constant.
Rides2Work likes this.
2015 DL650
Clayyalc is offline
post #4 of 21 Old 06-01-2018, 11:45 PM Thread Starter
Thanks, Clayyalc. I have stock headlights which, as I (far from an electrical technician) calculate, total 10A continuous. I only used the 20A fuse because that`s what the guy who makes the kits shows in his sample installations. Maybe because of the "flash to pass" condition, which temporarilly draws double? Any rate, I don`t use that feature save for a few time when I have triggered it inadvertently.
Yeah, the screw connections do seem a bit chintzy to me, though I don`t know what they are rated for. On the other hand, the designer specifically shows my setup on his website and other riders are apparently using the same setup with no problems.
It sounds like you saying that I might not have made a good connection. It`s tough to get much more torque on those tiny little screws, but maybe I did not have enough? Also a little challenging to get all the strands stuffed into the box. Is there some kind of crimp I can put on the wire end and then screw into the fusebox connector?
bdesj is offline
post #5 of 21 Old 06-02-2018, 01:04 AM
Clayyalc's Avatar
Wire ferrules work well to get a good contact.
2015 DL650
Clayyalc is offline
post #6 of 21 Old 06-02-2018, 04:59 AM Thread Starter
Whatever the cure, I think you`re right about the bad connection being the root cause. I ran out of time yesterday before I could test for shorts downstream, but I`ll do that over the weekend to be sure. Watched a YouTube video about the ferrules that you suggest and they look like a good idea. Alternatively, I wonder if tinning the ends of the wire might be a good measure? Curious as to how other people have run headlights through a PC-8 and how it has been doing for them.
bdesj is offline
post #7 of 21 Old 06-02-2018, 09:01 AM
I've trimmed a large wire, 12ga to remove a few strands and then tinned the end, soldered it, to fit in a connection.
Outbackwack likes this.
post #8 of 21 Old 06-02-2018, 09:21 AM
Hogges's Avatar
Tinning (soldering) the ends of wires is considered a bad practice for screw connections. The reason is that the tin creeps over time when under pressure, so while it will work great initially the resistance will increase over time as the connection loosens. Use bare copper.
Rolex and Outbackwack like this.
Hogges is offline
post #9 of 21 Old 06-02-2018, 09:23 AM
D.T.'s Avatar
High resistance and high current don't go together well.
Fuse won't open if current is lower than fuse rating. 20A seems pretty huge for that small terminal block though. Cut it off and use another spot.
If you had a IR camera and saw how hot it gets you really could have known.
D.T. is offline
post #10 of 21 Old 06-02-2018, 12:34 PM
That's one of the advantages of the PC8 over the fuse box I used on our 650's is that you can use wire ferrules. I had to use crush on wire loops thingy's (technical term) that the mount screw pass through. I put on a little dielectric grease to assist with oxidation prevention too.
Hatchi likes this.
gdrew is offline
